Classical Mechanics Problem: Particle in a Square Potential Well
11 replies · 3K views · last reply
Jozefina Gramatikova
CLASSICAL MECHANICS
Typeset homework problem 1 defining a 1D square well potential U(x) equal to -u for |x| less than or equal to a and 0 for |x| greater than a, with parts (a) and (b) about mechanical energy E and period.
[/B]
E=U+K[/B]
Handwritten physics notes on lined paper showing a square well potential U(x) = -U0 for |x| <= a and 0 for |x| > a, with energy E = U(x) + K, part a) energy ranges, and part b) a period sketch of particle position against time between -a and a.
Guys, can you please help me with part b) ? I am not sure how to find the velocity. Thanks
  • Typeset homework problem 1 defining a 1D square well potential U(x) equal to -u for |x| less than or equal to a and 0 for |x| greater than a, with parts (a) and (b) about mechanical energy E and period.
  • Handwritten physics notes on lined paper showing a square well potential U(x) = -U0 for |x| <= a and 0 for |x| > a, with energy E = U(x) + K, part a) energy ranges, and part b) a period sketch of particle position against time between -a and a.
    50288802_758179237899437_8167705243417575424_n-jpg-_nc_cat-106-_nc_ht-scontent-flhr4-1-jpg.jpg
First off, find the range of mechanical energies. What could it possibly be if the motion is bounded? What does "bounded" mean classically?
Is it -u<E<0 ? The motion of the system is bounded if it begins at a point situated between two forbidden regions, the system’s trajectory will never leave the allowed region where it started (otherwise it would have to cross one of the forbidden regions).
Any relevant equations linking kinetic energy to velocity ?
Equation typeset in LaTeX: K = m x-dot squared over 2, the kinetic energy expression with the dot notation for the time derivative of x.
  • Equation typeset in LaTeX: K = m x-dot squared over 2, the kinetic energy expression with the dot notation for the time derivative of x.
Could you tell me if this is true?
If U=-u , then E ≈ 0
if U=0, then E ≈ -u
No, I can tell you it is not true.
U is the potential energy
E is the total energy of the particle, an independent variable in this exercise.
As you almost say (well, guess) in #3, the given information tthat the particle is bounded leads to ##-u \le E < 0##.
With K the kinetic energy and, as you say, E = K + U you can write down the bounds of K and thereby the bounds of v. And derive the period of the motion.
Handwritten derivation on lined paper: T = s/v = 2a/v, K = E - U(x) = mv^2/2, v^2 = 2(E - U(x))/m, v = ±√(2(E - U(x))/m), then U(x) = -U gives v = ±√(2(E-U)/m) and U(x) = 0 gives v = ±√(2E/m).
  • Handwritten derivation on lined paper: T = s/v = 2a/v, K = E - U(x) = mv^2/2, v^2 = 2(E - U(x))/m, v = ±√(2(E - U(x))/m), then U(x) = -U gives v = ±√(2(E-U)/m) and U(x) = 0 gives v = ±√(2E/m).
    7594_2276574659287142_7618848920235409408_n.jpg?_nc_cat=100&_nc_ad=z-m&_nc_cid=0&_nc_ht=scontent.jpg
Ah...the curse of negative numbers...
Please, remember K is always a positive number.
Perhaps it might help if you considered a concrete example. Suppose ##K= \frac{2}{3}u## where ##u>0##. What is ##E##?
