Is click chemistry really viable for in vivo applications?
  • Thread starter Thread starter gravenewworld
    Chemistry
Click chemistry, particularly the Staudinger ligation and Huisgen cycloaddition, faces significant challenges for in vivo applications due to low reaction yields at physiological concentrations, with reported yields of only 0.003% and 0.8%, respectively. The kinetic barriers are substantial when compared to enzymatic bioconjugation, which operates at much higher rate constants. Despite skepticism regarding its viability, some practitioners assert that click chemistry is already being successfully applied in real-world scenarios. There is ongoing interest in exploring alternative applications of click chemistry beyond fluorescent tags, including potential uses in mass spectrometry and polymer science. The discussion highlights a need for further exploration of the practical implications and effectiveness of click chemistry in living organisms.
gravenewworld
With the huge interest in click chemistry for in vivo applications--the staudinger ligation and the Huisgen cycloaddition, I was wondering, just how viable are these reactions in real world settings? Assuming second order kinetics, the fastest ever reported Staudinger ligation click reaction had a rate constant of 7.7x10^-3 M-1s-1 and the fastest ever Huisgen click reaction has kinetic rate constant of 2.3 M-1s-1. In other words, at concentrations of 1uM (which is near physiological concentration ranges of drugs etc), for a rxn time of 1h, and assuming that we get complete conversion and no side products, that those reactions will produce yields of 0.003% and 0.8% respectively.
The kinetic barrier reported seems like a huge obstacle to me. For comparison's sake, enzymes that bioconjugate work with rate constants on the order of 2.7 x 10^6 M-s-1. So really, how viable is the click chemistry approach for in vivo application? Are we primed for failure?
Chemistry news on Phys.org
Boy, I love theoreticians who come up with all kinds of explanations and reasons why an experiment should be "primed for failure" and sound very convincing too, using the "right" numbers, yet disregard the obvious: it is already working! Don't rely on the numbers given by pseudo-chemists in pseudo-scientific journals. Just because it is published, it does not have to be true (and often isn't). It is perfectly viable in in vivo applications -- as long as you are willing to actually go and do it. If you continue finding reasons for why it should fail, you'll probably miss the boat.
I wouldn't classify Staudinger as a click reaction, and which one is the "Huisgen click"?
http://www.datasea.info/avatar1.jpgIf you continue finding reasons for why it should fail, you'll probably miss the boat.
Absolutley true on all points. I was really trying to play devil's advocate with the post. So what other uses can click chemistry be used in vivo besides just clicking probes? Fluorescence is highly sensitive and can work on concentrations within the picomolar range, but can click chemistry be used for applications besides just fluorescent tags without needing large concentrations to work in vivo? And will it ever work in a human? Sure you can get away with 100uM concentrations in rats, but what about a human?
I don't follow this well enough to be able to suggest more than Google search terms, but I have this recollection that they're also interested in applying these sorts of in vivo chemical techniques for mass spectrometric studies using isotope tags. Of course, the real advantage to "click chemistry" for non-chemists is that you can buy the materials from your favorite vendor without having to bug the nearest synthetic organic chemist. Heh.
There's also a fair bit of interest in this methodology in the polymer & materials science communities in my observations, especially as it relates to being able to functionalize polymers and modify surfaces. So while "real world," definitely not in vivo. Unless they plan on dosing something with the surface-modified nanoparticle for some reason, naturally.
A lot of click chemistry is applied to cell surface modifications--feed your cells an unnatural sugar that bears and azide or alkyne which then goes through the cell's machinery to express that sugar on the cell surface. Once that happens, "click" your substrate (probes or whatever) to your cell.
Now, what exactly is the turnover of sugars on the cell surface? Cells aren't static, but are constantly shedding and modifying their glycocalyx. So let's say we feed our cells a sugar bearing an azide/alkyne, just how long is it going to be on the cell surface? Couple that with the slow reaction time of the Staudinger ligation and huisgen cycloaddition, just how good of a signal to noise ratio can one obtain from in vivo? Interestingly, after more digging, Joeseph Fox's group at the University of Delaware has found a set of tetrazine diels alder rxns that occur in water/cell media with no catalysts with rate constants on the order of 10^4.
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3166440/
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
