Climate paper peer review scandal?
A significant scientific scandal is emerging regarding the validity of several recent peer-reviewed climate papers that attempt to reconstruct historical temperature records. At least eight of these papers, particularly those involving senior climatologists from the Climate Research Unit (CRU) at the University of East Anglia, may require reevaluation due to undiscovered errors that were not identified during the peer review process. This situation raises concerns about the reliability of contemporary climate studies and the foundational data used by the U.N. Intergovernmental Panel on Climate Change (IPCC) in its assessments. The failure of peer review to catch these errors highlights potential weaknesses in the current climate research framework. The discussions also note the absence of legitimate sources for citations in ongoing debates about the validity of these studies.
Mk
http://www.ncpa.org/sub/dpd/index.php?Article_ID=18512
A scientific scandal is casting a shadow over a number of recent peer-reviewed climate papers. At least eight papers purporting to reconstruct the historical temperature record times may need to be revisited, with significant implications for contemporary climate studies, the basis of the U.N. Intergovernmental Panel on Climate Change's (IPCC) assessments. A number of these involve senior climatologists at the British climate research centre CRU at the University East Anglia. In every case, peer review failed to pick up the errors, says the Register.
Here's the short story:
http://www.theregister.co.uk/2009/09/29/yamal_scandal/
And the long detailed one:
http://bishophill.squarespace.com/blog/2009/9/29/the-yamal-implosion.html
We were aware of that, however there are no peer reviewed studies or other acceptable publications available yet.
Ah, I see it on the ClimateAudit now.
What happened to the rule of using legitimate sources for citations?
On August 10, 2025, there was a massive landslide on the eastern side of Tracy Arm fjord. Although some sources mention 1000 ft tsunami, that height represents the run-up on the sides of the fjord. Technically it was a seiche. Early View of Tracy Arm Landslide Features Tsunami-causing slide was largest in decade, earthquake center finds https://www.gi.alaska.edu/news/tsunami-causing-slide-was-largest-decade-earthquake-center-finds...
Hello, I’m currently writing a series of essays on Pangaea, continental drift, and Earth’s geological cycles. While working on my research, I’ve come across some inconsistencies in the existing theories — for example, why the main pressure seems to have been concentrated in the northern polar regions. So I’m curious: is there any data or evidence suggesting that an external cosmic body (an asteroid, comet, or another massive object) could have influenced Earth’s geology in the distant...
