Why is the amplitude maximum at the open end of a closed and open end tube?
In summary, when considering a sound wave inside a closed end and opened end tube, the displacement amplitude at the closed end is always zero due to no motion of air, while at the open end it is always maximum due to a sudden reduction in pressure caused by the wave spreading out. This can be better understood by considering a single pulse and understanding the principles of reflection at both ends of the pipe.
cks
165
Consider a scenario of a sound wave inside a closed end and opened end tube.
We always learn that the displacement amplitude at the closed end is always zero but at the opened end is always maximum.
My friend can see it quite intuitively.
For the closed end, we expect there is no motion of air. So, the amplitude is zero.
But I don't find it intuitive to imagine how the amplitude at the open end is of maximum?
Thank you.
Hi cks! :smile:
Sound is a traveling longtudinal pressure difference.
A sound wave in a pipe is a standing wave, and therefore cannot exist unless there is reflection at both ends.
First consider single a pulse (not a wave).
At a closed end, a pulse of high pressure is reflected as a pulse of high pressure.
At an open end, a pulse of high pressure is reflected as a pulse of low pressure (and vice versa) … a 180º "change in phase".
This is because when the high pressure pulse leaves the pipe, it spreads out spherically, rapidly becoming atmospheric pressure, and suction is created behind it.
In other words, there is a reduction in pressure behind it, and this low pressure will pulse back down the pipe.
It is this sudden reduction in pressure cause by the ability of the wave to spread out which makes the difference.
That's fairly clear for a single pulse, though not so clear for a wave, but the principle is the same.
For a lot of detail, including a rather good animation, see this Australian site: http://www.phys.unsw.edu.au/jw/flutes.v.clarinets.html#time
(Another way of looking at it is that the open end of the pipe is at high pressure, and the air beyond it is at ordinary pressure, so it behaves like a boundary between two fluids of different pressure, and so a reflection is to be expected. :smile:)
Thanks for your answer. It's quite clear and straightforward.
Related to Why is the amplitude maximum at the open end of a closed and open end tube?
1. What is a closed end open end tube?
A closed end open end tube is a type of tube that has one end sealed off and the other end open. This creates a cavity within the tube that can be used for various purposes, such as containing a gas or liquid, conducting experiments, or storing materials.
2. How does a closed end open end tube work?
The closed end of the tube acts as a barrier, preventing any substances from escaping. The open end allows for substances to be inserted or removed from the tube. This creates a controlled environment for experiments or storage.
3. What are the advantages of using a closed end open end tube?
There are several advantages to using a closed end open end tube. It allows for the containment and control of substances, prevents contamination from outside factors, and can be easily sealed and reopened for use. Additionally, it is a cost-effective and versatile option for scientific experiments and storage.
4. What materials are commonly used to make closed end open end tubes?
Closed end open end tubes can be made from a variety of materials depending on the intended use. Some common materials include glass, plastic, metal, and rubber. These materials are chosen for their durability, chemical resistance, and ability to create an airtight seal.
5. What are some common applications of closed end open end tubes?
Closed end open end tubes have many applications in the scientific world. They are commonly used in chemistry experiments to hold and mix substances, in biology experiments to culture cells, and in physics experiments to study pressure and other properties of gases. They are also used for storage of materials such as chemicals, liquids, and small objects.
  • Electromagnetism
  • Other Physics Topics
