Closed set of rational numbers
In summary, A is a closed set that contains every rational number between 0 and 1, but it does not uniquely specify which irrational numbers are included. You need to show that any irrational number within the unit interval is an accumulation point for at least one sequence of rational numbers in the unit interval.
Andy_ToK
43
Hi,
here is the question, if A is a closed set that contains every rational number r: [0,1], show that [0,1] is a subset of A.
But, how could A be closed? If A is closed, R^n-A is open, so any point in R^n-A would have a open sphere around it and this open sphere wouldn't intersect A. apparently, this is not true. eg. sqrt(0.5) has no open sphere around it that is disjoint from A.
[0, 1] is closed set containing every rational number between 0 and 1, is it not? Ponder that.
[0,1] is but A isn't, i think. because A doesn't contain those irrational numbers between 0 and 1.
Why not? The problem you stated doesn't assert otherwise.
Incidentally, A is not uniquely specified -- there are lots of sets that have the property of both being closed and of containing every rational number in [0, 1], and the hypotheses is merely that A is one such set.
I think your title shows a misunderstanding. You titled this "closed set of rational numbers", which implies it contains only rational numbers, but the question is about a closed set that contains rational numbers- it doesn't say only rational numbers and clearly that cannot be true. If A is to contain [0,1] then clearly it contains irrational numbers as well. The point of the exercise is to show that any closed set that contains all rational numbers in [0,1] must also contain all irrational numbers in [0,1].
Note that in order for A to be closed (by premise!), A must include all accumulation points for sequences in A.
In particular, it means that A must contain all accumulation points for all sequences whose terms are rational numbers in the unit interval.
What you then need to show is that any irrational number within the unit interval is an accumulation point for at least one such sequence of rational numbers in the unit interval.
Remember that the rationals are dense in the reals..
Thank you all.
1. What is a closed set of rational numbers?
A closed set of rational numbers is a set that contains all of its limit points. This means that for every sequence of rational numbers within the set that converges to a limit point, that limit point is also included in the set.
2. How is a closed set of rational numbers different from an open set of rational numbers?
An open set of rational numbers does not include its limit points, while a closed set does. This means that a closed set is a more inclusive set compared to an open set.
3. Can a closed set of rational numbers have an infinite number of elements?
Yes, a closed set of rational numbers can have an infinite number of elements. This is because it contains all of its limit points, which can be infinitely many.
4. How are closed sets of rational numbers used in mathematics?
Closed sets of rational numbers are used in various areas of mathematics, including topology and real analysis. They are useful in proving theorems and properties related to limits, continuity, and compactness.
5. Is the set of rational numbers itself a closed set?
Yes, the set of rational numbers is both closed and open. This is because it contains all of its limit points (closed), but does not include its endpoints (open).
  • Topology and Analysis
