Coefficient of kinetic friction?
The discussion revolves around calculating the distance a monkey and sled travel up an inclined track, given an initial speed of 4 m/s, a 20º incline, and a coefficient of kinetic friction of 0.20. The total deceleration combines the effects of friction and gravitational components, resulting in a deceleration rate of approximately 5.3 m/s². It is determined that the sled takes about 0.75 seconds to stop, covering a distance of approximately 1.5 meters. The conversation also raises a hypothetical scenario about the sled's movement on a curved track, suggesting further exploration of the physics involved. The calculations emphasize the importance of understanding friction and gravitational forces in motion on inclines.
doxigywlz
Okay, I've never done this before and I sure hope there is somebody out there who can help me. I've tried answering this question EVERY way possible and cannot come up with the right answer.
In a circus performance, a monkey is strapped to a sled nd both are given an initial speed of 4 m/s up a 20º inclinedj track. The combined mass of monkey and sled is 20 kg, and the coefficient of kinetic friction between sled and incline is 0.20. How far up the incline do the monkey and sled move?
The amount of mass doesn't matter, so your just dealing with deceleration due to gravity (constant) and friction (also contant in this case).
Well that solution is correct, but it's more complicated than needed.
Deceleration from constant fiction is equal to the coefficient of friction times the rate of accleration of gravity. The friction is relative to the component of gravity normal (perpendicular) to the track
or .2 x cos(20).
So the rate of frictional decleration is
.2 x cos(20) x 9.8 m / s^2.
The component of gravitation deceleration is relative to the component parallel to the track:
sin(20) x 9.8 m / s^2.
Total deceleration rate is the sum of these 2 rates
.2 x cos(20) x 9.8 m / s^2. + sin(20) x 9.8 m / s^2 = 5.3 m / s^2.
Since the initial speed is 4 m/s it takes (4 / 5.3) ~= .75 seconds to stop.
Since it's linear deceleration, the average speed is 1/2 the inital speed, in this case 2 m/s, so the total distance traveled is 2 x .75 ~= 1.5m.
Ok, math wizards, what if the track were curved with radius R? Assume the track starts off horizontally, and R is large enough that the track doesn't go beyond veritcal before the sled stops.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
