Does Damping Affect the Coherence Between Broadband Signals?
  • Thread starter Thread starter jollage
    Coherence Signals
Damping in a linear system affects the coherence between broadband signals, specifically the magnitude-squared coherence. When input A(t) passes through a damped linear system L, high frequencies can be significantly attenuated, potentially leading to a coherence value less than 1. The discussion highlights that in deterministic systems, coherence properties should theoretically remain intact, while stochastic systems introduce noise that degrades coherence. A specific example is provided where high-frequency components are diminished, questioning whether coherence remains at 1 for those frequencies. The conversation suggests that analyzing the correlation functions of A(t) and B(t) can clarify the impact of damping on coherence.
jollage
The coherence I'm asking about is also known as magnitude-squared coherence.
Let's say we have input A(t) and we look at the output B(t), the system L is linear but it has damping effect on the signals. In a long time, this damping will literally kill the high frequencies to zero.
My question is if A(t) contains a broadband spectrum, and let A(t) go through the system L, will the coherence between A(t) and B(t) be less than 1, or just equal to 1?
Jo
If I understand you correctly: if L is a deterministic linear system then the coherence properties of B(t) should be equal to the coherence properties of A(t). IIRC, the transfer function of L determines how the coherence propagates from A(t) to B(t), and while stochastic systems will degrade signal coherence, deterministic systems do not.
There is some discussion here: http://www.dtic.mil/dtic/tr/fulltext/u2/682486.pdf
Hi Andy,
Thanks for your reply.
OK, I see what you mean. By stochastic system, do you mean there is noise going into the linear system? Of course, in this case the coherence would decay.
Ley's consider the damping being very strong, literally killing all the high frequencies. Let's say we have A(t)=sin(2*pi*t)+sin(2*pi*9*t) as an input. Going through the linear system with damping, the high frequency 9 Hz is killed, so B(t)=c*sin(2*pi*t), c is some constant less than 1 because frequency 1 Hz is also damped. Do you mean the coherence between A(t) and B(t) is 1 for frequency 9Hz? I can't see that.
Jo
Not exactly- although noise is often modeled with stochastic equations. 'Stochastic' simply means that the time evolution of a system is not deterministic- to model a stochastic processes (e.g. diffusion- Brownian motion is the 'canonical problem') requires statistical analysis.
Jo
I don't really understand how you are modeling the damping- but in any case, if you compute <A(t)A(t+τ)>/<A^2> and compare that to <B(t)B(t+τ)>/<B^2>, you will have your answer.
A possible reference for you is Marathay's "Elements of Optical Coherence Theory", which is more general than you need but is very complete.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
