Why Isn't My Coil Simulation Achieving the Expected 8pT Signal in Maxwell?
The user is attempting to simulate a coil in Maxwell to achieve an expected 8pT signal at 50 meters, based on specific coil properties from a referenced paper. Despite using both voltage and external circuit types in the simulation, they are unable to reach the desired signal strength. Concerns are raised about the accuracy of the frequency, suggesting it may be closer to 575kHz rather than 575Hz, as the low reactance at 575Hz seems inconsistent with the coil's specifications. Additionally, the user seeks guidance on selecting the appropriate resistance value for the sinusoidal source, noting its significant impact on the results. The discussion highlights the need for careful verification of parameters to achieve accurate simulation outcomes.
azita3285
hello every one
i want too simulate a coil with with Maxwell and transient solution type:
this coil is in a paper and i want to simulate it
i attach the coil properties. in this paper the dimension of coil is given such:
diameret:12cm; length=84cm; moment=30a-m^2; construction= 16 turns AWG#12; coil voltage=65Vrms=91Vpeak; frequency=575hz; depth rating=30m
and @ 50 meter from this antenna we have 8pT signal
i calculate the equivalent circuit:
you know the AWG#12 diameter is 2.053mm and has 5.211 mohm/m, and as we say, the coil voltage is 91v, so we have:
Rcoil=30.85mohm; Lcoil=.15mH
i simulate the coil with the thickness of 2.053 which is the same of diameter of wire.
so i simulate it with two type of winding (voltage and external)
1) in voltage type i fill in the blanks such these:
initial current=0 ; resistance=30.85mohm, inductance=.15mH , voltage=91*cos(2*pi*575*time)
i run this but i don't achieve the 8pT signal @ 50 meter from antenna. i attache it by the name of coil with voltage
2) external: in this type i create an external circuit with maxwel circuit editor and import it in the maxwell. i attach the circuit and the maxwell simulation with the names of circuit and coil with external circuit.
another question is that what value i have to select for the resistance which is series with the sinusoidal source? this value has deep effect in my result.
please help me and suggest me some solution, i don;t have time and i have to simulate it :( :(
thank you
That inductance at 575Hz has a very low reactance (sub-Ohm). Are you sure the frequency isn't more like 575kHz? That construction with so few turns with that large excitation voltage don't seem to line up, IMO.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
