Calculating Expected Value and Variance of Coin Toss Results
The discussion focuses on calculating the expected value and variance of the product of heads and tails from three coin tosses, defined as Z = XY, where X is the number of tails and Y is the number of heads. The relationship Y = 3 - X allows for the expression of Z in terms of X, resulting in Z = (3 - X)X. The expected value E(Z) is calculated as 2 multiplied by the probability of getting 1 head and 2 tails, and vice versa, yielding E(Z) = 2 * ⅜ + 2 * ⅜. Additionally, E(Z^2) is computed as 4 multiplied by the same probabilities, confirming the calculations seem accurate. The analysis effectively demonstrates the expected outcomes of the coin toss scenario.
pawlo392
Member warned that the homework template should not be deleted
A coin had tossed three times. Let ##X##- number of tails and ##Y##- number of heads. Find the expected value and variance ##Z=XY##.
My solution:
We know, that ##Y=3-X##, so ##Z=(3-X)X## for ##X=0,1,2,3##.
##Z=2## for ##X=1,2## and ##Z=0## for ##X=3,0##
So, ##E(Z)=E((3-X)X))= 2 \cdot ⅜ +2 \cdot ⅜.##
Because we're interested in events :
1 head and 2 tails, and 1 tail and 2 heads.
And ##E(Z^2)=4 \cdot⅜ +4 \cdot ⅜##. What do You think?
That looks good to me.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
