Weight Change of Coke Can When Opened: Explained
  • Thread starter Thread starter Himal kharel
    Balance Weight
When a can of Coke is opened, the initial reading on a sensitive balance increases due to the force exerted by the escaping liquid and CO2 gas. This force creates a temporary net increase in downward pressure on the scale. Once the liquid fully exits the can, its mass decreases, leading to a reduction in the reading. Additionally, as CO2 escapes and the fizzing stops, the overall weight further decreases, potentially influenced by some evaporation. The discussion raises questions about the need for deeper analysis in understanding these weight changes.
Himal kharel
when a can of coke placed in a sensitive balance is opened what happens to the reading?
the answer of this question is given first increases and decreases.
can anyone explain this?
can coke opens and liquid bursts out of it with some acceleration which means: can applies force on liquid which means: liquid applies force on can::
so net force on can increase so does reading
now when the liquid is completely out the mass of can is reduced and so does reading
In a less dramatic scenario, the CO2 gas is escaping from the hole in the top and this pressure is causing an increase in downward force. Once the fizzing has stopped and there is less CO2 in there, the final weight will be less (and there may be some water evaporation too.
Should I be doing all this thinking for you? Is this a h/w question?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
