FUNKER
- 120
- 0
So what is the deal with cold fusion these days what is hindering the progress of an ubundace of energy?
Please Explain
Please Explain
I have argued that the very term "cold fusion" (or how about "chemically catalyzed fusion"?)is a contradiction. I can't remember who now (may even have been in a different forum), but someone argued that though the water bath could be at room temp, some atoms could still reach energies required for fusion. I don't buy that and still consider it an oxymoron. Otherwise you could define your system to as big as you want and at some point, the system as a whole can be considered "cold." In my view, if the individual atoms fusing together are of an energy level associated with fusion, that's "hot" fusion. In "cold" fusion, it appears the goal (current websites are sufficiently vague there is some question here) was to get the individual atoms to fuse at energy levels not normally associated with fusion: a physical impossibility like you said.Originally posted by jcsd
The electrolytic approach was the subject of a hoax/poor scientific method whioch generated a lot of hype at the time, it's now generally agreed that it is physically impossible to achieve cold fusion via this method.
The sound barrier and flight itself are often touted as examples of science saying something is "impossible" only to be proven wrong. This is NOT the case. Scientists always knew that flight and supersonic flight were theoretically possible, after all, we've seen birds fly and bullets have been supersonic for about as long as we knew of the sound barrier. The problem was always an ENGINEERING one.Its too greater' theory to live down and cast off i believe, this is just history repeating itself, 'We will never be able to fly' etc.
Originally posted by Tyro
My physics is a little rusty compared to some of the others on the board, but I heard about work which involved acetone or some other hydrogen-rich hydrocarbon (IIRC) and collapsing air bubbles within it. Apparently, viscous effects aside, the collapsing bubbles would generate temperatures sufficient to initiate fusion as their radius tends to zero. From what I remember, the scientists who did work on it reported a steady stream of neutrons (apparently a sign of fusion) but it has not been independently corroborated. People are questioning as to whether there was a mistake/malfunction in the original researchers technique/apparatus, or if the others trying to duplicate the results actually did duplicate it exactly.
Russ, to comment on what you said regarding the superfluous nature of the hot/cold fusion label, I agree in its current state it is a bit ambiguous, but I think the temperature label applies to your supposed reacting fuel. So for a Tokamak it would be the confined hydrogen, for an acetone-based experiment, the acetone sitting in the beaker.
A lot of scientists also don't want to get involved in that field, because after all the false/misreported results, it has become quite taboo. Personally, I am hedging my bets.
Humm, in chemistry there is a phenomenon wherein a proton captures and electron, becoming a neutron, low temps 9If I recall properly) sort of a form of a 'fusion' event, so maybe there are conditions we simply haven't found yet.Originally posted by russ_watters
(SNIP)[/color] I have argued that the very term "cold fusion" (or how about "chemically catalyzed fusion"?)is a contradiction. I can't remember who now (may even have been in a different forum), but someone argued that though the water bath could be at room temp, some atoms could still reach energies required for fusion. I don't buy that and still consider it an oxymoron. Otherwise you could define your system to as big as you want and at some point, the system as a whole can be considered "cold." In my view, if the individual atoms fusing together are of an energy level associated with fusion, that's "hot" fusion. In "cold" fusion, it appears the goal (current websites are sufficiently vague there is some question here) was to get the individual atoms to fuse at energy levels not normally associated with fusion: a physical impossibility like you said. (SNoP)[/color]
Humm, aggressive responce, I said "in Chemistry" as I had learned that little tidbit of knowledge about the proton capturing electrons from My Chemistry Book so you have (sorta) 'shot off' in a (kinda) wrong direction, plus I never said the "cold fusion process" (which does produce hydrogen) in this 'reaction', it was seen as an occurance in a chemical reaction,(? Do I recall that properly?) and I suspect its been known of well before 'Cold Fusion' had ever been heard as words.Originally posted by mathman
This is not a chemical process! It only happens for very energetic collisions. At ordinary temperatures, you simply get hydrogen.
I haven't specified 'cold' myself, simply looking at fusion, and there is a place wherein protons capture electrons, to become neutrons, NOT at elevated extremes of temp, NOT at elevated extremes of pressure, either (as I recall)...demonstrates that some of the inner nuclear particles do things we haven't yet understood/figured-out.Originally posted by mathman
Could you clarify what you mean? Fusion processes start with hydrogen, deuterium, or tritium, and end up with heavier isotopes.
But, hot fusion occurs in plasmas. What you're describingOriginally posted by jcsd
Basically it uses a muonic hydrogen atom, where the atom's electron has been replaced by the electrons heavier cousin, the muon. A muonic atom has a smaller radius than an electronic atom, which menas that nuclei can get closer together aiding fusion, it also catalyses itself as more muons are produced when nuclei fuse, but the problem is muons have a very short half-life which greatly reduces the chain reaction.
True.jcsd said:Basically it uses a muonic hydrogen atom, where the atom's electron has been replaced by the electrons heavier cousin, the muon. A muonic atom has a smaller radius than an electronic atom, which means that nuclei can get closer together aiding fusion,
NO one is saying we can't produce energy- just that there is no evidence that this particular method works. Rather than saying "we will never be able to fly" it is saying "we will never be able to fly by just flapping our arms" or, even more accurately, "there is no current evidence that we will ever be able to fly just by flapping our arms"!FUNKER said:Its too greater' theory to live down and cast off i believe, this is just history repeating itself, 'We will never be able to fly' etc.
