Collapse of building #7 on 9/11
  • Thread starter Thread starter alantheastronomer
    Building Collapse
The NIST report attributes the collapse of building 7 on 9/11 primarily to thermal expansion of a floor beam that disrupted a support column. While some participants in the discussion question if there were other contributing factors, the report explicitly lists three additional factors and provides recommendations for mitigation. A participant raises the idea that the shared basement with the twin towers might have influenced the building's stability, but this connection is not mentioned in the report. The findings indicate that the fire alone was sufficient to explain the collapse, dismissing the structural damage from the North Tower debris as insignificant. Overall, the discussion emphasizes the complexity of the collapse and the importance of the official findings.
alantheastronomer
The official NIST report on the collapse of building 7 on 9/11 states that the thermal expansion of a floor beam due to the fires disrupted a support column on the thirteenth floor, and that is what ultimately caused the building to collapse. Is this the sole cause or could there have been other contributing factors?
Yes.:sleep:
Likes russ_watters
Have you read the report? There are three additional explicitly listed contributing factors and more than a dozen recommendations for mitigating them and other potential contributing and tangential factors. Your one sentence summary is a good start, but the reality is far more complicated.
Likes berkeman
No, I just read the Wikipedia version. What are the contributing factors that you know of? Do you have a link to the report? The reason I'm asking is that when I was listening to the radio when it was happening, they mentioned that building 7, unlike the others in the area, shared a common basement with the twin towers, although I haven't heard mention of this since. This got me to wondering about, when the North Tower collapsed, might it have pressed air into building 7's basement, weakening it's foundation?
Looking (quickly) at the report, I see no mention of this common basement when they discuss the connection between building 7 and the rest of the WTC.
It appears that the report found that the fire was sufficient to explain what happened to building 7. They say that even the structural damage from the debris of the North Tower played no significant role.
Likes russ_watters
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
