Will These Two Planes Collide?
  • Thread starter Thread starter Femme_physics
    Collision
The discussion revolves around the potential collision between two planes, A and B, with differing velocities and flight paths. Plane A flies vertically in a circular arc at 2050 km/h, while Plane B travels horizontally at 848 km/h. Participants clarify that the paths of the two planes do intersect, leading to the possibility of a collision. The conversation includes calculations regarding angular velocity and distance over time, ultimately concluding that the planes may come very close to colliding. The final distance between the two planes after 10 seconds is calculated to be 5.3 km.
Femme_physics
Plane B flies in a direct line at constant velocity Vb = 848 km/h. Above him, at a distance of 7.5 km/h flies airplane A. Airplane A flies at a constant velocity Va = 2050 km/h. It flies in a vertical pathway in an arch of the radius R equal 5 km.
In the drawing is described the initial position of both planes.
If both planes carry on flying as described in the question, will they collide?
http://img687.imageshack.us/img687/5315/planthingy.jpg
Solution Attempt
I don't get how it's possible for them to collide. One just flies in an arch, so I guess that means in a circular pathway, that means that plane A will be directly at point B while plane B will be waaaaaaaay off ahead
Like this:
Right?
Or am I misreading/mistranslating something?
http://img803.imageshack.us/img803/8307/ababababa.jpg
Femme_physics said:
Right?
You are misreading something. In your second diagram, the paths do not even overlap. But in the first diagram, you can see that the horizontal path of plane B will intersect the semi-circle path of plane A. (The question is at what time will the paths overlap.)
No the question is "will they collide", not "at what time will they collide"
Just at a guess I'd say they will either collide or come quite close. You don't seem to understand the diagram. Plane B files slowly for a short distance and plane A flies a longer distance but at a higher speed and they meet up (or come close) at the point where their flight paths intersect, as clearly shown on the diagram (not on your diagram of course, which just illustrates your misunderstanding of the original diagram)
Your incorrect interpretation: Since the paths don't even intersect, how can they possibly collide?
Correct interpretation: Ah... the paths do intersect. Figure out at what time they overlap to see if the planes collide.
yes, although you should do the math to see whether it's kaboom or just WHOA that was a near miss.
LOL great comment. Will do :wink:
Femme_physics said:
Now I have these formulas to relate angular velocity to distance:
Try the third on the left, with angular acceleration equal to zero.
(Careful here: the alpha in your formula table is angular acceleration, which is not your angle alpha.)
Femme_physics said:
But which angle do I use-- alpha or beta?
Try (beta + 90o).
Femme_physics said:
And...am I at the right track?
Yep. :smile:
Glad to see you everywhere! :)
I don't understand how to use this formula you suggested-- I mean, do I just plug in the value in degrees?
i.e.
120 = 0.114t
i.e.
120 = 0.114t
Same thing! :)
Usually we do everything in math and physics (all angles) in "radians".
Degrees is another unit for the same thing, so you have to convert.
180 degrees corresponds to \pi radians.
Btw, you're not so much on the right track, but on the right trajectory! :wink:
Ah, thanks,
Solved it! :D
http://img62.imageshack.us/img62/1008/pipipiw.jpg
Since the distance difference between them is so small, I guess that means KABOOMAGA!
:smile: :smile: LOL brilliant!
Sorry, I take that back. You're on a bad trajectory, just because: KABOOMAGA! :wink:
Femme_physics said:
heh ;)
Shouldn't I use centripetal acceleration in this formula?
Or does it really stand for tangential acceleration?
Edited: It really stands for angular acceleration, which is similar to tangential acceleration.
(Tangential acceleration is not the same as angular acceleration - they differ by a factor R.)
Centripetal acceleration is quite another friend (which is radial).
I'm trying to find the difference in aerial position after 10 seconds.
I found out through this formula
delta alpha = omega x time +at^2/2
That delta alpha - 1.13889
Converting that to degrees that 65.25 degrees
Now I'm not sure where is that angle. Is it here?http://img135.imageshack.us/img135/149/angleangle.jpg
Good morning Femme_physics! :smile:
Angles are used in circular motion.
An angle is measured between the line from the center of the circle to the initial position, up to the line between the center of the circle and the final position.
So no, it is not where you have drawn it.Edit: Oh, and please avoid using alpha in this context, because you're using a formula that uses alpha (not "a") for angular acceleration, which is zero is this problem (and will be in most problems that are coming your way).
Just a note: If A flies at constant velocity it moves along a straight line, not along a circle. Its speed can be constant, instead.
ehild
Good morning ILS! :)
[quotes]An angle is measured between the line from the center of the circle to the initial position, up to the line between the center of the circle and the final position.
[/quote]
Ah, makes sense!
Edit: Oh, and please avoid using alpha in this context, because you're using a formula that uses alpha (not "a") for angular acceleration, that is zero is this problem (and most problems that are coming your way for now).
Check confirmed and affirmed :) Got it.Now they're asking me to find the distance in "aerial line" between the two planes after 10 seconds. Which distance do they want? This or that?
http://img109.imageshack.us/img109/6171/dissss.jpg
Uploaded with ImageShack.us
That. :smile:
LOL! Left or right one, I mean?
Right! :smile:
(one I mean)
(text deleted)
Ah, I think I'm on to something then! Give me a moment :)
Solved.
5.3 km :)
Thanks!
