How Does Momentum Change in a Two-Dimensional Collision?
  • Thread starter Thread starter Donnie_b
    Collisions
In a two-dimensional collision involving a 5.00 kg Ball A moving at 12.0 m/s and a stationary 4.00 kg Ball B, the momentum conservation equation is applied. After the collision, Ball A moves at a 38.0º angle and Ball B at a 52.0º angle relative to Ball A's original direction. To solve for Ball A's momentum post-collision, it's essential to break down the momentum into x and y components and apply trigonometric functions based on the given angles. The discussion highlights the importance of using vector diagrams to visualize momentum components and emphasizes that the hypotenuse is not necessary for calculations. The second response in the thread is considered more accurate in guiding the momentum calculations.
Donnie_b
A 5.00 kg Ball A moving at 12.0 m/s collides with a stationary 4.00 kg Ball B. After
the collision, Ball A moves off at an angle of 38.0º right of its original direction. Ball B 52.0º left of Ball A's original direction. After the collision, what is the momentum
of Ball A?
P1 + P2 = P1' + P2'
60 + 0 = P1' + P2'
After this I have no idea where to go. We would need a velocity however there isn't one given.
I'm assuming a vector diagram would be useful, but I am not too sure what that would look like.
You must break up the momentum into the x and y components, and sum up in each direction. Draw a diagram to keep track of everything.
I don't have the hypotenuse to be able to do that. The only thing I could think of would be x =(60-y) and y=(60-x)
Ok so I also asked this question on Yahoo answers, and some person gave me this:
60=P’[sin(38) + cos(38)]
60= P’[1.25144222]
P'=60 / 1.25144222
P'=47.9446826 =
P'= 48 kgm/s
Now I have never seen anything alike this taught to me. Does this have any truth to it?
I was also given this which seems more... legit
PX(x) = 5kg*12 m/s = 60
PX(y) = 5kg*0 m/s = 0
PY(x) = 4kg * 0 m/s = 0
PY(y) = 4kg * 0 m/s = 0
PX'(x) = cos(38)*PX'
PX'(y) = sin(38)*PX'
PY'(x) = cos(52)*PY'
PY'(y) = sin(52)*PY'
Then use conservation of momentum in each direction
60 = PX(x) + PY(x) = PX'(x) + PY'(x)
0 = PX(y) + PY(y) = PX'(y) + PY'(y)
from this we see
PX'(y) = - PY'(y)
and
PX'(x) = 60 - PY'(x)
then plug in the sine formulas for each component.
you now have two equations with two variables.
solve one for PY' and plug into the other to solve for PX'
You don't need the hypotenuse to break into components. You have the angle given after the impact, use trigonometry.
[EDIT]
The first response is completely off. The second one seems right to me as well.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
