What is the Correct Color Code for a 1KΩ ± 10% Resistor?
The correct color code for a 1KΩ ± 10% resistor is brown, black, red, and silver, indicating the first significant digit as 1 (brown), the second as 0 (black), and the multiplier as 100 (red). Confusion arises from variations in online calculators, but the standard convention dictates that the first digit cannot be black, which eliminates incorrect options. It's emphasized that there must be at least four bands, including tolerance, and that "none" is not a valid color. The discussion also touches on the historical context of resistor color coding and the evolution of manufacturing tolerances. Understanding these conventions is crucial for accurately identifying resistor values.
Hardik Batra
I want to know color code for this resistor
---> 1KΩ \pm 10%
I have check in two sites. This sites showed me different color code for this resistor value.
Which one is right i don't know i am confused!
http://www.digikey.com/us/en/mkt/calculators/4-band-resistors.html
(this sites show me brown,orange and silver color)
http://www.engineering.com/Library/ArticlesPage/tabid/85/ArticleID/120/Color-Code-for-Resistors.aspx
(this sites show me black,brown,orange and silver color)
Shouldn't it rather be brown, black, red, silver? (10 x 102 ± 10%)
Is it possible for one resistor value there are many color code?
The way I learned it is
first significant digit = 1 = brown
second significant digit = 0 = black
multiplier = 102 = red
and that the first digit can never be 0, so it can't start with black. That way, there is only one possibility.
can we take
first significant digit = 0= black
second significant digit = 1 = brown
multiplier = 103 = orange
or
first digit can never be 0, but you can use this color.
first significant digit = 1= brown
can we ignore 2nd significant digit?
Hardik Batra said:
can we take
or
As far as I understand it, no, both of these are not acceptable. There is a minimum of four bands (including tolerance) and the first can't be black.
Likes 1 person
You have seen this site.
brown,none ,red and silver also give us 1 kΩ resistor.
none,brown,orange and silver also give us 1 kΩ resistor.
brown,black ,red and silver also give us 1 kΩ resistor.
black,brown,orange and silver also give us 1 kΩ resistor.
This is wrong?
which one is correct.
This is wrong?
Come on, I already told you what the correct one was and why. Just because you found a web-applet that allows you to input nonsense doesn't mean that all these possibilities are valid.
This is wrong?
The first and second are wrong because "none" isn't a color and you must have at least 4 bands.
The fourth one is wrong because you can't start with black.
That leaves us with the correct answer, which is your third choice.
AFAIK component color coding has been added to but not changed since it began shortly after the turn of the previous century. My first Electronics Instructor was a Naval Radio operator and maintainer who taught us a (cleaned up) version of the military mnemonic for codes -
Bad Boys Race Our Young Girls Behind Victory Garden Walls
Obviously it stuck and it also works provided you note the number of bands to determine if additional values beyond resistance are listed. Commonly these are the Tolerance bands, but the first 3 bands are always Ohms.
There is another question about this topic.
If there is one diode and 4 color band are design with different color.
And i want to decide the resistor value.
How i know the 1st significant figure is started from which point(means which is the first color band at right hand side one or left hand side)?
I'm not sure what you mean, but some small diodes have the part number coded as color bands. For example the common 1N4148 may have yellow brown yellow grey bands. Color bands or other markings are always at the cathode end of the diode.
Most resistors are made with values from a standard sequence of values. See http://www.logwell.com/tech/components/resistor_values.html. Nearly all the resistors you will see in real life have values from the E24 series.
If you try to read the bands from the wrong end, either the code is invalid (e.g. the first band can never be silver or gold), or you get a non-standard value, or the value is too small or too big to make any sense. Nearly all resistor values in electronic circuits are between 10Ω and 10MΩ.
If a resistor really does have a non-standard value, it will probably be printed as a number, not color coded.
---> 1KΩ \pm 10%
Many decades ago when most resistors were 10% or 5% this would be a Brown, Black, Red, Silver (eg four bands).
As manufacturing tolerance levels improved it became necessary to add more bands (more significant figures) so you could tell the difference. From some places you might order a 10% part but be sold a 2% part which would be Brown, Black, Black, Brown, Red.
