Combining Errors for Stress Calculation
  • Thread starter Thread starter charlesltl
    Combination Errors
The discussion focuses on calculating the standard error for a stress-related calculation involving multiple variables A, B, and C, along with their respective standard errors. The user presents their equations for combining errors and seeks validation on their approach, specifically regarding the use of square root formulas for error propagation. There is confusion about whether the suggested method aligns with standard error calculations or represents a mean square error instead. The user requests clarification on the correctness of their calculations and the appropriate method for determining the standard error. The conversation highlights the complexities of error propagation in statistical calculations.
charlesltl
Hello Everyone,
I am trying to compute the standard error of a stress related calculation.
Let's consider the following:
A \pm \DeltaA
B \pm \DeltaB
where A and B are the mean values while \DeltaA and \DeltaB are the respective standard errors.
The common combination of errors formulas are as follows:
y = A + B then, \Deltay = √(\DeltaA2+\DeltaB2)
y = k. A then, \Deltay = k.\DeltaA
Now my equation is,
y = k2 . [ A + k1 . ( A + B + C ) ]
May I know if my following working is correct?
( A + B + C )
= √(\DeltaA2+\DeltaB2 + \DeltaC2)
k1 . ( A + B + C )
= k1 . √(\DeltaA2+\DeltaB2 + \DeltaC2)
= √[\DeltaA2 + (k1 . √(\DeltaA2+\DeltaB2 + \DeltaC2))2]
= √[\DeltaA2 + k12 . (\DeltaA2+\DeltaB2 + \DeltaC2)]
= k2 . √[\DeltaA2 + k12 . (\DeltaA2+\DeltaB2 + \DeltaC2)]
I am confused because I was suggested that it should be,
= k2 . √ [k1. \DeltaA2 + k12 . (\DeltaA2+\DeltaB2 + \DeltaC2)]
Your input in highly appreciated.
Charles
Mathematics news on Phys.org
That last appears to be the "mean square error" rather than the "error".
Would you suggest that my working to compute the standard error is correct?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
