Combinations - selecting 7 persons
  • Thread starter Thread starter rajatgl16
    Combinations
The discussion revolves around calculating the number of ways to select 7 persons from a group of 5 Indians, 4 British, and 2 Chinese, ensuring at least 2 individuals are chosen from each nationality. Initial calculations led to conflicting answers, with one participant arriving at 300 and another at 180, while the answer booklet states 100. The correct approach involves recognizing the combinations of selecting 2 Chinese, 3 British, and 2 Indians, or 2 Chinese, 2 British, and 3 Indians, leading to the final calculation of 100. Participants acknowledged errors in their reasoning and calculations, ultimately clarifying the correct method.
rajatgl16
In how many ways 7 persons can be selected from 5 indian, 4 british and 2 chinise, if atleast 2 are to be selected from each country.
you have to choose two chinese forced, at least two british and two indians, and one between british or indian. so you have
1*\frac{4!}{2!2!}*\frac{4!}{2!2!}*(3+2)=180
the last term: 3 indians+2 british
hey I have answer booklet (not solution). And in it answer given is "100".
I tried it as,
At least 2 persons have to be slected form each country so :
ways of selecting 2 persons from 5 indians is 5C2
ways of selecting 2 persons from 4 british is 4C2
ways of selecting 2 persons from 2 chinese is 2C2
Thus ways of slecting 6 persons form entire group is 5C2 * 4C2 * 2C2
Now 1 person has to be selected from remaining 3 Indians and 2 british and 0 chinese
possible way of selceting 1 person is 5C1
Thus final answer to select 7 persons is 5C2 * 4C2* 2C2 * 5C1=300 so its also wrong
for nCk you mean n!/(k!*(n-k)!) ? If yes we computed the same thing, or better, you are right, I've done an error in the third factor, it is actually 5C2=5!/(3!2!), for me it's 600, but i made the same reasoning as you did, and i think it's right, if we understand the problem correctly.
Then may be ans in my ans booklet is wrong.
You've overcounted some. Imagine the British people are labeled A,B,C and D.
Scenario 1: You pick two British, A and B. Then you pick two Indians. Then you pick your last person from the five remaining people and pick person C.
Now imagine instead you pick two British, A and C. You pick the same two Indians as before. You pick your last person from the five remaining people and the person is B.
In both situations you've picked the same set of people but you counted them separately
Officeshredder is right. There are two possible situations, you pick 2 chinese 3 british and 2 indians or you pick 2 chinese 2 british and 3 indians, so you have
2C2*4C3*5C2+2C2*4C2*5C3=100
Hmm. I was wrong. Thanks guys for helping me,
