Finding Voltage Gain in Common Collector Configuration Without RE
  • Thread starter Thread starter erece
    Collector
In a common collector configuration without the emitter resistor (RE), the voltage gain can be challenging to determine. The voltage gain formula typically includes RE, but its absence necessitates considering the transistor's output resistance (Ro). The internal impedance of an ideal current source is indeed very high, which affects how the circuit behaves. Since the output resistance of the transistor cannot be ignored in this scenario, it plays a crucial role in calculating the voltage gain. Understanding these relationships is essential for accurately analyzing the circuit's performance.
erece
for the common collector configuration shown i need to find the voltage gain.
The voltage gain formula is AV = (β+1)(roll RE)/(rπ+(β+1)(roll RE)
But in the circuit RE is absent . So how do we consider it ??
Nothing is given about the current source.
from the circuit theory i know that the internal impedance of a current source is very high (am i correct ?).
So in this case how do we relate it ?
Yes the impedance of an ideal current source is infinite.
Since resistance attached to the output of the transistor is infinite you can't ignore the output resistance of the transistor itself. You've no doubt been ignoring it in most of your circuits but this could only be done because Ro (of the transistor) >> than anything attached to the transistor output and it was connected in parallel to anything attached at the output.
