MergeSort Algorithm for Sorting Arrays - Step by Step Guide
  • Thread starter Thread starter courtrigrad
    comp sci
The discussion focuses on implementing the MergeSort algorithm for sorting arrays, emphasizing the importance of the merging step after sorting the two halves. The initial steps involve checking if the array has one element, splitting it into two halves, and sorting each half. The challenge lies in efficiently merging the two sorted halves, leveraging their sorted nature for optimal performance. Participants suggest prioritizing the merging algorithm to enhance efficiency. Overall, the conversation highlights the recursive nature of MergeSort and encourages exploring additional resources for coding examples.
courtrigrad
Let's say you want to write an algorithm for MergeSort given the following:
Code:
 public void(int[]a, int n1, int m, int n2)
I know the algorithm:
MergeSort
1. If array has 1 element don't don anything
2. Split array in two halves
3. Sort the first half and the second half
4. Merge both halves into one.
Any help is appreciated :smile:
Code:
MergeSort
The tough part of this problem is number 4. I'd suggest working on this part first... assuming you have an array (whose length can be anything >=2) that has the top half sorted, and the bottom half sorted, write an algorithm that merges the two. You want to make this as efficient as possible. You want to take advantage of the fact that the top and bottom are each sorted. Compared to this part, the rest is easy.
Mergesort is a neat application of recursion.
I remember downlopading java gives a lot of free soring examples. why not chekc it out ?
