How to Multiply Two Positive Integers Using Recursion | Comp Sci Questions
  • Thread starter Thread starter courtrigrad
    comp sci
A recursive method to multiply two positive integers using repeated additions can be defined as a*b = a + (a * (b-1)). The provided code has errors, particularly in the recursive call where it incorrectly adds the arguments. The correct implementation should ensure that the recursive function is called with two parameters. Additionally, for the hello method, the output formatting needs correction; it should use concatenation instead of a comma. Overall, the discussion highlights the importance of proper syntax and logic in recursive function implementation.
courtrigrad
Hello all
If we want to write a recursive method that multiplies two positive integers using repeated additions, we know that: a\times b = a + (a\times(b-1)) Would this be correct:
Code:
// pre: a and b are positive
// post: returning the product of a and b.
public int mult(int a, int b )
a*b = a +(a * (b-1))
if( b ==1)
return(a);
else
  return mult(a + a*(b-1)))
Also if you had:
Code:
public void hello(int n )
   System.out.println("hello n = ",n);
   if(n > 1)
      hello(n-1);
   System.out.println("goodbye n = ", n);
How would you find the output when a 3 is passed? I got a bumch of hellos and goodbyes, but I got it wrong
Thanks :smile:
are these right?
courtrigrad said:
Code:
The above line is unnecessary.
courtrigrad said:
Code:
if( b ==1)
return(a);
else
Your second return line here is wrong. You're calling mult which should have two arguments...
courtrigrad said:
Also if you had:
Code:
   if(n > 1)
      hello(n-1);
Thanks :smile:
I think it should be:
System.out.println("hello n="+n);
Instead of a comma you need a "+".
