Compactness and FIP related problem
  • Thread starter Thread starter librastar
librastar
This question is related to Topology.
Let X be a compact space and let {Ca|a\inA} be a collection of closed sets, closed with respect to finite intersections. Let C = \capCa and suppose that C\subsetU with U open. Show that Ca\subsetU for some a.
Here is how my solution goes:
Consider the complement of Ca, X - Ca, is open.
Since X is compact, \cup(X-Ca) is the open cover of X and \cup(X-Ci) for i = 1,2,...,n is a finite subcover of X such that X = \cup(X-Ci).
Now since X is compact and by the finite intersection property, C is nonempty.
But here is where I got stuck...I don't know how to continue to finish the problem.
I think this may be caused by mistakes in my reasoning, but I can't spot it.
Please help me on this question, any help is welcomed.
Thanks in advance.
The closed under finite intersections is important for more than just the fact that C is non-empty. For example, let X=[-2,2], C_1 = [-2,1] and C_2=[-1,2]. Then C=[-1,1]\subset (-\frac{3}{2}, \frac{3}{2} )=U but neither C_1 or C_2 are contained in U
Sorry but I still don't quite get it...
So the compactness of X comes into play because now I can generate a open set U that is "big" enough to contain some or all of Ca?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
