If p is a covering map with B compact and fiber of b finite, E compact
7 replies · 4K views
EgoKilla
Let [itex]p: E \rightarrow B[/itex] be a covering map.
If B is compact and[itex]p^{-1}(b)[/itex] is finite for each b in B, then E compact.
Note: This is a problem from Munkres pg 341, question 6b in section 54.
I begin with a cover of E denote it [itex]\{U_\alpha\}[/itex].
I want to reduce this to a finite subcover (thus showing that E is compact).
First I use the fact that p is a covering map and thus open to send this cover of E to a cover of B.
Denote the image of [itex]\{U_\alpha\}[/itex] under p by [itex]\{W_\alpha\}[/itex]
Then since B is compact I can reduce this to a finite subcover: [itex]\cup_{i=1}^n W_i[/itex].
Here is where I get stuck, I'm not sure how to send this finite subcover of B back over to E. I'm not even sure if I'm going about this the right way.
Any help is greatly appreciated, thanks.
The natural thing to do is of course looking at ##p^{-1}(W_i)##. The problem is that
[tex]U_i\subseteq p^{-1}(W_i)[/tex]
and equality does not hold in general because ##p## is not injective. So maybe you can do something with the fact that ##p## is a local homeomorphism and that it has finite fibers.
One thing I would do is first to replace the ##U_i## by a cover of smaller sets ##V_j## such that ##p:V_j\rightarrow p(V_j)## is a homeomorphism between open sets. Then think about how you can write ##p^{-1}(p(V_j))##.
Why are we allowed to replace the [itex]U_\alpha[/itex] by a smaller cover? But then once we have that it's just as simple as saying we can reduce the [itex]V_j[/itex] to a finite subcover since after we map them to B we can take a finite subcover of them and map them back using [itex]p^-1[/itex] since each open set in the image is then homeomorphic to its pre-image?
First try to obtain a finite cover of the ##V_j##. Then you can use that ##V_j\subseteq U_\alpha## for some ##\alpha## to obtain a finite cover of the ##U_\alpha##.
By the way, in topology we call the ##V_j## a refinement of the ##U_\alpha##. The fact that the ##V_j## has a finite subcover can then be stated as "Every open cover has a finite open refinement". This statement is equivalent to compactness.
Are you using that ##p^{-1}(p(V_j)) = V_j##? This is still not true. It is only true for injective maps. However, because you are dealing with a covering map, you can write ##p^{-1}(p(V_j))## in a better and more convenient form.
Sorry, I'm still confused about why we're even allowed to replace [itex]U_\alpha[/itex] by the [itex]V_j[/itex] at all.
We can write [itex]p^{-1}(p(V_j))[/itex] as a disjoint union of open sets in E, each of which maps homeomorphically to [itex]p(V_j)[/itex]. But this must be finite because of the finiteness of the fibers?
Yes, that is something you should think about.
Yes, even better: we can write ##p^{-1}(p(V_j))## as the finite union of some ##V_i##. So there exist a finite set ##I## such that
[tex]p^{-1}(p(V_j)) = \bigcup_{i\in I} V_i[/tex]
Using this, can you then find a open cover of the ##V_j## and hence of the ##U_\alpha##?
