Is My Comparator Circuit Textbook Explanation Incorrect?
The discussion centers on a homework question regarding a comparator circuit from a textbook. The poster expresses confusion about the circuit's operation, specifically questioning the textbook's explanation of how the output voltage behaves when the reference voltage is set at 4V. They argue that if the non-inverting input (V+) is fixed at 4V, the output should be negative when the inverting input (V-) is equal to or greater than 4V, contradicting the requirement for the LED to light. Other participants confirm that the textbook is incorrect, clarifying that the comparator output is high when the non-inverting input exceeds the inverting input. This resolution alleviates the poster's concerns about their understanding of the circuit.
Jimmy87
We have to answer questions from a particular circuit (comparator) in our textbook for homework. The circuit is attached to this thread. I haven't started the questions yet as I don't even understand the circuit! Based on my notes I think my textbook is wrong and would appreciate it if someone could glance at the attachment and confirm or deny the case.
Open loop gain = A (V+ - V-) where V+ is the non-inverting input, V- is the inverting input of the op-amp and A is the amplification factor.
Where it says next to the diagram "suppose we want the reference voltage to be 4V. This would mean that the LED would light when the input voltage is equal to or greater than 4V". This is what I think is wrong:
This means V+ (non-inverting input) is fixed at 4V. If Vin (which is V-) is equal to or greater than this then according to the open loop gain equation, the output voltage would be negative. This means that the anode of the diode is negative which means no current will flow. From my class notes it says the anode must be positive for a diode to light.
So either my class notes are wrong or the textbook is wrong? Huge thanks to anyone that can help me with this!
You are correct and the book is wrong. The comparator output goes high when the + input is higher than the - input. Or said differently, the output is high when the - input is below the + input.
Likes 1 person
Phew! Thought I was missing something. Thank you berkeman!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
