Comparing Vacuum Capability of Pump Models WELCH 1375 & PFEIFFER DUO65
The ultimate pressure of a vacuum pump indicates its vacuum capability, with the WELCH 1375 (1 x 10^-4 Torr) outperforming the PFEIFFER DUO65 (2 x 10^-3 Torr) in terms of vacuum quality. Both pumps have the same speed of 35 CFM, but the choice may also depend on other factors like price, size, power consumption, noise, and durability. The speed versus ultimate pressure curve suggests that while a higher CFM allows for faster pump-down times, a lower CFM pump can still achieve the same ultimate pressure if time is not a constraint. For applications requiring frequent access to the vacuum chamber, a faster pump may be more practical. Ultimately, the selection should align with specific needs and operational requirements.
vultac
Dear All,
Appreciate if you can guide me on understanding the ultimate pressure of vacuum pump.
I have two models for review.
One has ultimate pressure of 1 x 10^-4Torr the other has 2 x 10^-3Torr.
From this can it be said that the vacuum capability of the first pump (1 x 10^-4) larger range? is better than the second pump?
Both has speed 35CFM.
Model 1 Pump WELCH 1375
Model 2 Pump PFEIFFER DUO65
Thanks for your help.
These specs indicate coarse vacuum pumps, where the quality of the ultimate vacuum is not that critical.
My guess is other parameters, such as price, size, power use, noise or durability are also factors in the purchase decision.
If those don't matter in your case, then yes there is a factor of 20 difference in the vacuum quality produced by the two pumps.
Hi, thanks for replying.
What is the signifance of the curve for the Speed vs the Ultimate Pressure. What does the curve implies?
ie if i found a machine that is running at 20CFM (15 less) but having 1 x 10^-4torr. is that ok?
The pump will not exhaust the volume to the ultimate pressure immediately,
A higher CFM rating unit will pump down a volume faster than the lower rated pump, but if you can afford the time, the lower CFM rated pump will serve equally well.
Do note that if you have any sort of a setup where you need to repeatedly access some element that is operating when in vacuum, it can be a real pain to wait for the pumpdown each time you adjust something.
What drives the need for a vacuum?
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
12K
