Comparison test on second species integrals
Rono
Determine if the following integrals are convergent or divergent. Explain why.
\int^{1}_{0} \frac{1}{1-x^{4}} dx
I've tried using Comparison Test, using f(x) = \frac{1}{1-x^{4}} and\; g(x) = \frac{1}{1-x}, 0 \leq f(x)\leq g(x) in ] 0,1 [ and I know g(x) is divergent. My question is if its plausible that, by using Comparison Test, if g(x) is divergent, will f(x) be divergent too?
No. Not plausible. You want a divergent integral that's less than f(x), not greater. Hint: factor 1-x out of (1-x^4).
It was my first thought, but I considered it too simple to be true, thanks!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
