Completely inelastic collision.
In a completely inelastic collision scenario involving a wooden block and a gun on a frictionless air track, the system is initially at rest before the gun fires a bullet. After the bullet is fired, the glider moves in the opposite direction with a velocity calculated as (-mbvbx)/mp. Once the bullet embeds itself in the block, the glider's velocity is zero, indicating that all momentum is transferred to the block. The displacement of the glider while the bullet travels is determined to be -mbL/(mp+mb), raising questions about the inclusion of bullet velocity in the calculations. The discussion emphasizes the importance of understanding relative velocities and momentum conservation in inelastic collisions.
Jimmy25
A wooden block and a gun are firmly fixed to opposite ends of a long glider mounted on a frictionless air track. The block and gun are a distance L apart. The system is initially at rest. The gun is fired and the bullet leaves the gun with a velocity vb and impacts the block, becoming imbedded in it. The mass of the bullet mb and the mass of the gun-glider-block system is mp.
a. What is the velocity of the glider immediately after the bullet is fired?
b. What is the velocity of the glider immediately after the bullet comes to rest in the block?
c. How far does the glider move while the bullet is in transit between the gun and the block?
(The bullet is fired in the positve x direction)
a. I found the the velocity of the glider after the gun is fired as (-mbvbx)/mp.
b. The velocity of the glider after the bullet becomes embedded in the block should be zero.
c. After putting my algebra skills to the test, I found that the glider is displaced -mbL/(mp+mb).
My problem is with C it appears the units are correct in this answer but I am not confident in that the velocity of the bullet is not contained in the equation. Is this answer possible?
a) When the bullet is fired with the velocity vb, the gun, block and the glider move in the opposite direction. because the gun and the block are fixed to the glider. So vp = ...?
b)when the bullet is air born, the block is approaching with the velocity vp, so the combined velocity of the system after impact is...?
c) Since the bullet and glider are moving in the opposite direction, the relative velocity of them is...?
Finally t = L/relative velocity.
