Completing the Square with Coefficient on X^2
  • Thread starter Thread starter fuzzface89
    Coefficient Square
The discussion focuses on completing the square for the equation involving various quadric surfaces, specifically when dealing with negative coefficients. The user struggles with how to handle the negative coefficient for the y-term while completing the square. Clarifications are provided on how to maintain balance in the equation when adding terms, emphasizing the importance of tracking added values. The conversation highlights the necessity of factoring out the negative coefficient to simplify the process. Ultimately, understanding these steps is crucial for accurately transforming the equation into its standard form.
fuzzface89
Consider all possible surfaces that can be formed from the variations of
\[PlusMinus]x^2\[PlusMinus]4y^2\[PlusMinus]z^2+2x+8y+6z==-6,
that is, find and describe all the different quadric surfaces you can make from this equation by using different signs on the degree 2 terms. For each one, find the standard form of the equation.
I am having problems completing the square when the coefficient is negative.
For the case where the y-coefficient is negative:
(x^2 + 2x + 1) + (-4y^2 + 8y + _ ) + (z^2 +6z + 9) = -6 + 1 + _ + 9
dividing by -4 gives: (y^2 - 2y + _ )
Adding (b/2a)^2: (y^2 - 2y + 1)
Condensing: (y - 1)^2
Now, does the coefficient 4 come back as positive or negative, as in
4(y - 1)^2 or -4(y - 1)^2
Also, when adding to the other side of the equation, does the -4 multiply to the added quantity?
Thanks for any help
(-4y2 + 8y )
= -(4y2 - 8y + __) + something
You're going to add a positive number inside the parentheses, but you have really added a negative number, so to keep the expression in balance, add the positive of that negative number.
Make sense?
What else you should do to make your life simpler is to bring out the coefficient on the 2nd degree term so that you have
-4(y2 - 2y + __) + something
Just keep track of what you really added to the overall expression.
Okay, thanks for helpin me out
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
