Complex Conjugation in the Continuous Time
Taking the complex conjugation of a continuous time signal, such as a sinusoidal signal, is mathematically valid and can be done before sampling. The physical correctness of this operation depends on the context and representation of the complex numbers involved. If the complex numbers represent modulated signals, their conjugation can be useful for processing, especially in signal recovery. However, the implications of this operation should be carefully considered in relation to the specific application. Ultimately, the feasibility of complex conjugation in this context is supported by mathematical principles, but its practical implications must be evaluated based on the signal's characteristics.
EngWiPy
Hello all,
I have a continuous time signal v(t), and mathematically I want to take the complex conjugation of it for processing purposes, but I am not sure if this is physically correct. Is it?
Thanks
Is v a complex variable?
Its discrete time samples are, but I want to take the conjugation before sampling. Is it correct physically speaking?
All you've told us is that you have some complex numbers. Whether or not any operation on those numbers is "physically correct" will depend on what those numbers represent.
I have some complex numbers which are modulated into a continuous sinusoidal signal. Usually, these numbers are recovered by demodulation of the noise-free signal. I want to know if taking complex conjugation of a continuous time signal, like a sinusoidal signal, is possible in reality.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
