Is Complex General Relativity the Key to Understanding Naked Singularities?
Jim
Complex (not because its difficult !), but because certain elements of classical, real GR
are allowed to assume complex (real + imag parts) values, such as the metric or connexion.
I am wondering if anyone is aware of any legitimate work going on in this area ??
I have already been shanghied by a crackpot's book (blaha's) only to find out that he has never published on this subject either on arxiv or ref.'d journals.
The subject is fascinating simply because black hole event horizons become complexified if they exceed `extreme' classification, and go over into naked singularities (NS).
Since GR is limited to a real manifold, the problem of NS might become tractable in a complex version of GR...
Any thoughts, references ?
http://arxiv.org/abs/gr-qc/9312032
Ashtekar Variables in Classical General Realtivity
Domenico Giulini
"Chapter three considers complex General Relativity and shows how its field equations can be obtained from a variational principle involving only the self dual part of the connection. In chapter four the (3+1)-decomposition is presented in as much detail as seemed necessary for an audience that does not consist entirely of canonical relativists. It is then applied to complex General Relativity in chapter five, where for the first time Ashtekar’s connection variables are introduced. The Hamiltonian of complex General Relativity is presented in terms of connection variables. In chapter six the constraints that follow from the variational principle are analyzed and their Poisson brackets are presented. In chapter seven we discuss the reality conditions that have to be imposed by hand to select real solutions, and briefly sketch the geometric interpretation of the new variables. In chapter 8 we indicate how the Hamiltonian has to be amended by surface integrals in the case of open initial data hypersurfaces with asymptotically flat data. It ends with a demonstration of the positivity of the mass at spatial infinity for maximal hypersurfaces."
Very nice pedagogical intro to LQG, Atyy.
However, I was not thinking of LQG, but just a generalization of the GR field eqs, via either a complex metric or connexion. In particular, I am interested in learning of such a formulation which is then applied to either Kerr or Kerr-Newman BHs, and whether in the extremal limits, such BHs morph into naked singularities. I suspect there is something terribly intractable about formulating GR on a complex (3+1) manifold, or many people other than Ashtekar would've attempted it by now, in an attempt to generalize GR.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
