Now you can take the limit as ##z## approaches ##-1##.
  • Thread starter Thread starter jjr
    Complex Limit
jjr
Calculate the following limit if it exists
## \lim_{z\to -1}\frac{\sqrt{z}-i+\sqrt{z+1}}{\sqrt{z^2-1}} ##
the branch of root is chosen so that ## \sqrt{-1}=i##
I tried most of the same things that I tried earlier today ( https://www.physicsforums.com/threads/complex-limit-help.813800/ ).
1. No obvious way to simplify the expression and get rid of the zero in the denominator.
2. Tried to multiply the numerator and denominator with the complex conjugate ## \sqrt{\bar{z}^2-1} ##, which did give me a ## \sqrt{2} ## in the denominator. The problem with this is that if ## z ## goes to ##-1##, then I suppose ##\bar{z}## goes to ## -1 ## as well. This means, in effect, that I multiplied with 0, and I don't think it's legit. (Yields a wrong answer (0) anyway).
3. Tried using l'Hopitals rule, but it doesn't remove any of the radicals which will still go to 0 no matter how many times I apply it.
4. Tried the transformation ## z = re^{i\theta} ##, but can't see how it would get me any further.
Any ideas?
Thanks,
J
edit: mistake
Likes jjr
I will take your word, because it makes perfect sense and it's the correct answer (suppose I should've mentioned that). Thanks.
No there was a mistake there. The first term should be multiplied by ##\sqrt{z} + i##
You get $$\frac{(\sqrt{z}-i)(\sqrt{z}+i)}{\sqrt{(z-1)(z+1)}(\sqrt{z} + i)} + \frac{\sqrt{z+1}}{\sqrt{(z-1)(z+1)}} = \frac{\sqrt{z+1}}{(\sqrt{z-1})(\sqrt{z} + i )} + \frac{1}{\sqrt{z-1}}$$
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
