Complex number equation - absolute value assumption
pinsky
I have a problem in understanding the procedures of a solved example. It goes like this.
\left ( \frac{z+i}{z-i} \right )^4 = -1
Therefor we can write:
\left | \frac{z+i}{z-i} \right | = 1
From that we can see that z is a real number because:
\left | z+i \right | = \left | z-i \right | \; \; \; , z=x+yi \; \; \Rightarrow y=0 \; \; z=x
So let's say that:
W = \frac{x+i}{x-i}=\frac{x^2-1}{x+1}+\frac{2x}{x+1}i
W^4 = -1
And from that they get the solutions by doing some additional steps which i understand. What i can't seem to understand is the transformation written in red. For I'm having a homework to solve:
\left ( \frac{z+1}{z-1} \right )^3 = -1
and I don't know if i can apply the same assumption as in the upper example cause i don't understand what happened.
Any help is appreciated.
because |ab| = |a||b| it's easy to prove that |a^4| = |a|^4
now take the norm of both sides of the first equation and use this
Thank you
[SOLVED]
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
