Complex number polynomial, with no root given
Jarfi
z^3 + (-5+2i)z^2 + (11-5i)z -10+2i =0 has a real root, find all the solutions to this equation.
I have only solved imaginary number polynomials with a given root, but this has no given root, how do I find the real solution? that I can then use to factor it and find the rest of the solutions.
If you have no other techniques available, you can always assume a real solution and see if it satisfies the equation.
Oh nevermind, I found out how you do it, you just define a as a real number, put it in and get a real and imaginary part, both real and imaginary part are suppost to be equal to zero, so their mutual solution is the available real solution, this gave me the answer of two.
I already knew the 2 was an answer but my teacher would frown upon me if I'd assume a solution.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
