Complex numbers: adding two fractions and solving for z
The discussion centers on solving the equation $$\frac{1}{z}+\frac{1}{2-z}=1$$, where the initial attempt led to incorrect results due to errors in combining fractions and miscalculating square roots. Participants pointed out that the common denominator should not be incorrectly manipulated, which led to confusion in the solution process. The correct approach involves recognizing that the equation simplifies to $$z^2 - 2z + 2 = 0$$, yielding the solutions $$1 \pm i$$. The conversation highlights the importance of careful algebraic manipulation when working with complex numbers.
lamefeed
Quadratic-formula and algebra
Been struggling with this one.. I keep getting the wrong answer, but that isn't the worst part, I can live with a wrong answer as long as the math behind it is correct(formulas etc.) .
So this is the culprit:
\Rightarrow \frac{z}{z(2-z)}+\frac{z-2}{z(2-z)}=1
\Rightarrow \frac{z+z-2}{2z-z^2+2z-z^2}=1
\Rightarrow \frac{-2}{2z-2z^2}=1
\Rightarrow -2z^2+2z+2=0
\Rightarrow \frac{-2\pm\sqrt{s^2-4*-2*2}}{2*-2}
\Rightarrow \frac{-2\pm\sqrt{-12}}{-4}
\Rightarrow \frac{2\pm4i\sqrt{3}}{4}
\Rightarrow \frac{1\pm2i\sqrt{3}}{2}
\Rightarrow \frac{1}{2}\pm i\sqrt{3}$$
And this is far from correct.. I should have gotten ## 1 \pm i##.
So I must have done some illegal operation(sick with the flu so my brain isn't working 100%..)
Cheers!
So this is the culprit:$$\frac{1}{z}+\frac{1}{2-z}=1
\Rightarrow \frac{z}{z(2-z}+\frac{z-2}{z(2-z)}=1
Cheers!
I noticed a couple of errors.
##\displaystyle \frac{z}{z(2-z)}+\frac{z-2}{z(2-z)} \ ## is not equivalent to ##\displaystyle \ \frac{z+z-2}{2z-z^2+2z-z^2} \ ##
The two terms have a common denominator. Don't add the denominators.
Also;
What is the square root of ##\ -12 \ ##?
Likes lamefeed
Oh, my. I feel so embarrassed.. I'll get right to it.
And when it comes to the root of ##-12## I forgot to do ## \sqrt{-12} \Rightarrow i\sqrt{4}\sqrt{3} = 2i\sqrt{3}##
Yup. Of course, once you correct the first error, you won't have a square root of ##\ -12## .
Consider it solved!
\frac{z+(-z)+2}{2z-z^2}=1 \Rightarrow
\frac{2}{2z-z^2} \Rightarrow
2=2z-z^2 \Rightarrow
z^2-2z+2=0 \Rightarrow
\frac{2\pm\sqrt{2^2-4*1*2}}{2} \Rightarrow
\frac{2\pm\sqrt{-4}}{2} \Rightarrow
\frac{2\pm2i}{2} \Rightarrow \\
1 \pm i
I got such a good feeling when I solved it. Feels weird, I'm 100% super excited! Thanks SammyS and fresh_42(reply in the old thread).
You can optimise
<br /> \frac{1}{z} + \frac{1}{2-z} = 1 \iff \frac{1}{z} = 1 + \frac{1}{z-2} \iff \frac{1}{z} = \frac{z-1}{z-2} \iff z^2 -2z +2 =0.<br />
and you get solutions ##1\pm i ##. If you have something of the form ##\frac{a}{f(x)} + \frac{b}{g(x)} = c ##, perhaps it's not such a hot idea to immediately mess with the common denominators and such.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
