How Are Dual Vector Components Determined by Basis Vectors?
Dual vectors are determined by their values on basis vectors, which means their components in a given basis are fixed by the basis itself. This leads to confusion about the variability of components, as they seem constant across different bases. The equation mentioned, e^i(e_j) = δ^i_j, is indeed reliant on the choice of basis, and may not apply to all orthonormal bases. The Riesz Representation Theorem allows for expressing functionals as inner products with vectors in the space, reinforcing the connection between dual spaces and their bases. Understanding these concepts is essential for grasping the nature of dual spaces and their components.
noahcharris
Hi everyone,
So I'm going through a chapter on dual spaces and I came across this:
"A key property of any dual vector ##f## is that it is entirely determined by its values on basis vectors.
## f_i \equiv f(e_i) ##
which we refer to as the components of ##f## in the basis ##{e_i}##, this is justified by
##e^i(e_j) = \delta^i_j## "
-- This doesn't make any sense to me. How are the components of the dual space only dependent on the basis of V? Wouldn't that mean the components are always the same? I thought the whole point of components was that they varied.
Also, is the second equation assuming a cartesian basis? (not sure what the technical term is) Because I can think of some orthonormal bases for which this doesn't hold. i.e. I can think of some orthonormal basis where 'picking off' the ith component does not yield 1.
I'm obviously confused.
Dual spaces in general just confuse me, I understand that the dual space is the set of linear functionals on V, and that they can be represented as 1-forms, but as far as the details go (coordinates and bases of the dual space) I'm completely lost. Any help would be much appreciated.
Mathematics news on Phys.org
Using the Riesz Representation of functionals in an inner-product space, you can express any functional as an inner product with a vector in the space. Implying that you would use the same basis set to express the representation (i.e. vector form).
https://en.wikipedia.org/wiki/Riesz_representation_theorem
Could you expand what you mean by 'vector form'? Are you talking about a differential form (covector)?
The vector form I was referring to is just the ##f_i = f(e_i)## notation you used.
Likes mattclgn
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
