Solving Composite Functions Questions - Help Needed
The discussion focuses on solving composite functions and finding specific functions that satisfy given equations. Participants explore how to derive functions f and g such that f(g(x)) equals a specified polynomial, using examples to illustrate the process. The importance of manipulating quadratic and linear functions to achieve the desired output is emphasized, alongside the application of the chain rule for differentiation. Additionally, the discussion highlights the need for careful algebraic manipulation to eliminate unwanted terms in the resulting expressions. Overall, the conversation aims to clarify the methodology for tackling composite function problems effectively.
F.B
This is the only section so far that i don't understand, i don't know how to
do some types of questions like the ones I am going to ask, can anyone please help me with these.
1. Let g(x)= x-3. Find a function of f so that f(g(x)) = x^2
2. Let f(x) = x^2. Find a function g so that f(g(x)) = x^2 + 8x + 16
3. Let f(x) = x + 4 and g(x) = (x-2)^2. Find a function u so that
f(g(u(x))) = 4x^2 - 8x + 8
4. Let y = f(x^2 + 3x - 5). Find y' when x = 1, given that f'(-1) = 2
in your first one you are given g(x) = x-3 ...you then have to find a function f of x such that f(x-3) in someway maps to x^2...as a little example:
suppose g(x) = x+1 and you need to find f(x) such that f(g(x))=x^3
Firstly let's find (x+1)^3...we get:
x^3 +3x^2 +3x +1... and this is 3x^2 +3x +1 too much!...now let's try and get rid of it...if we say f(g(x))=x^3-3x^2 we end up with...
(x^3 +3x^2 +3x +1) - 3(x^2 + 2x +1)...and after simplifying we have x^3 - 3x -2...still -1(3x+2) too much...
so now let's say f(g(x)) = x^3-3x^2 +3x...once you do the arithmetic you need to somehow get rid of 1...see what's happening? can you apply this methodology (or a better one) to your questions?
*edit in the 4th question...(didn't look at it carefully enough at my first visit) you can imagine that f(x^2 + 3x - 5) = f(g(h(x)) where g(x) = x^2 + 3x - 5 and h(x) is some other function of x...try to find h(x) such that it's effect on f(g(h(x))) is just enough that when you differentiate the result you have the correct terms in x to make f'(-1) = 2
(ie: if you decided to let h(x) = x^3 you'd have a serious case over over-kill because f(g(h(x))) would be x^6 +3x^3 - 5... and f'(x) here is going to be miles away from 2 when x = -1 :wink:)
one more thing...finish up by then finding f'(1) :smile:
(edit2...apologies for what may be an un-wieldy reply...I might need to practice saying what I mean without going round the houses )
Saying f(g(x)) = x2 is the same to saying that f(x - 3) = x2, right? Since g(x) = x - 3.
This problem means that you should find a function is terms of (x - 3), such that the result is x2.
Okay, I think I'll give you another example
Example:
Let g(x) = x - 5
Find f such that f(g(x)) = x2 + x
f(g(x)) should be a quadratic function, and g(x) is a linear one. So to get a second degree polynomial from g(x), we musy first square it, right?
Let's square it:
(x - 5)2 = x2 - 10x + 25
Now you have x2, but you only need x2 + x, not x2 - 10x + 25, right?
So x2 - 10x + 25 = x2 + x - 11x + 25 (the -11x + 25, you don't need, right?)
So we must try to eliminate that, first, try to eliminate the -11x part, using (x - 5). We must add another 11(x - 5), right?
So:
(x - 5)2 + 11(x - 5) = x2 + x - 11x + 25 + 11x - 55
= x2 + x - 30.
Now to get x2 + x, we need to add to that expression a constant 30, right?
So we have:
(x - 5)2 + 11(x - 5) + 30 = x2 + x.
Exactly what we want to find.
So f(x - 5) = (x - 5)2 + 11(x - 5) + 30
Let y = x - 5
So f(y) = y2 + 11y + 30.
That the function f you need to find.
For problem #2,
f(g(x)) = g(x)2, right?
f(g(x)) = x2 + 8x + 16 = (...)2
What should be (...), you think? Can you find g(x) from here?
Let's see if you can do problem #3 on your own.
If you are stuck somewhere, just shout it out. :)
You know the chain rule right?
\frac{dy}{dx} = \frac{dy}{dt} \times \frac{dt}{dx}
So:
\frac{dy}{dx} = \frac{dy}{d(x ^ 2 + 3x - 5)} \times \frac{d(x ^ 2 + 3x - 5)}{dx} = f'(x ^ 2 + 3x - 5) \times (2x + 3)
Can you get this?
What's the output of x2 + 3x - 5 at x = 1?
And you also know that f'(-1) = 2.
Can you go from here?
Can you get this? Is there anything left unclear? :)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
