How much ice is needed to cool 31055.04J of water from 42°C to 0°C?
  • Thread starter Thread starter cwill53
    Composite Rod
The discussion focuses on calculating the mass of ice required to cool 31055.04 J of water from 42°C to 0°C. The calculations involve using the specific heat capacity of ice (2100 J/(kg·°C)) and the latent heat of fusion for water (334,000 J/kg). The final result indicates that approximately 0.093 kg (or 93 grams) of ice is needed. Participants clarified that the temperature of the ice should remain at 0°C during the melting process, emphasizing the importance of phase change in the calculation.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with specific heat capacity and latent heat concepts.
  • Basic algebra for solving equations related to heat transfer.
  • Knowledge of phase changes in materials, particularly ice and water.
  • Study the principles of heat transfer in thermodynamics.
  • Learn about specific heat capacity and its applications in real-world scenarios.
  • Explore the concept of latent heat and its significance in phase changes.
  • Investigate practical applications of cooling systems involving phase changes.
Students and professionals in physics, engineering, and environmental science who are interested in thermodynamics and heat transfer calculations.
cwill53
Two rods, one made of brass and the other made of copper, are joined end to end. The length of the brass section is 0.300m and the length of the copper section is 0.800 m. Each segment has cross-sectional area ##0.00500m^2##. The free end of the brass segment is in boiling water and the free end of the copper segment is in an ice–water mixture, in both cases under normal atmospheric pressure. The sides of the rods are insulated so there is no heat loss to the surroundings. (a) What is the temperature of the point where the brass and copper segments are joined? (b) What mass of ice is melted in 5.00 min by the heat conducted by the composite rod?
$$H=\frac{dQ}{dt}=kA\frac{T_{H}-T_{C}}{L}$$
##k_{brass}=109\frac{W}{m\cdot K}## ##k_{copper}=385\frac{W}{m\cdot K}##
My answer:
a.
$$H=\frac{dQ}{dt}$$
$$H_{brass}=H_{copper}$$
$$(109\frac{W}{m\cdot K})(0.005m^2)\frac{100^{\circ}C-T_{c}}{0.3m}=(385\frac{W}{m\cdot K})(0.005m^2)\frac{T_{H}-0^{\circ}C}{0.8m}$$
$$T_{H,Cu}=T_{C,brass}=T_{2}$$
$$-1.8166667T_{2}+181.666667^{\circ}C=2.40625T_{2}\Rightarrow T_{2}=43.02^{\circ}C$$
b.
$$\frac{dQ}{dt}=103.5168J/s\Rightarrow \delta Q=(103.5168J/s)(5 min)=31055.04J$$
##c_{ice}=2100J/(kg\cdot C^{\circ})## ##L_{f,water}=334\cdot 10^3J/kg##
$$Q_{ice}=m(2100J/(kg\cdot C^{\circ}))(42^{\circ}C)+m(334\cdot 10^3J/kg)$$
$$31055.04J=(424342J/kg)m\Rightarrow m=0.073kg$$Is this correct?
I agree with your answer to a, but what relevance has 42C to part b?
I just plugged the 42C in for Tc in the right hand side or Th in the left hand side to get dQ/dt...I don’t know if this is correct.
Should I have used 42C in finding the quantity of heat for ice?
No. The ice is in an ice-water bath at 0 C, and the only thing happening is that the ice at 0 C is melting to form water at 0 C. It is not heating up to 42 C. The only place where the temperature is 42 C is at the junction between the copper and the brass.
Thanks for that. That alone just cleared up a lot of confusion I had. That means I should only be considering the heat produced from the ice changing phase heat lost to the ice-water bath.
From that I got m= 0.093 kg= 93 g.
cwill53 said:
Thanks for that. That alone just cleared up a lot of confusion I had. That means I should only be considering the heat produced from the ice changing phase.
From that I got m= 0.093 kg.
I wouldn't call it heat produced. I would call it heat lost to the ice water bath. I haven't checked your math, but your approach is correct. Also, I would express the result as 93 grams.
10K
