Composition of collateral rotations of a planet
To determine how a vector pointing to the Sun changes over time for a rotating and orbiting body, one must consider the composition of rotation matrices, which do not commute. The initial vector lies in the xz plane, and the problem involves calculating its evolution using angular speeds for both rotation and orbit. A proper derivation should start with the equations of motion rather than relying solely on rotation matrices. The discussion highlights the complexity of analyzing such systems, emphasizing that the order of rotations affects the outcome. Understanding these dynamics is crucial for accurately modeling the behavior of celestial bodies in motion.
erore
A body is orbiting the sun and rotates about its axis (z). My coordinate system is co-rotating with the body. I need to determine how does a vector that points to the sun change after a certain period of time. Initially the sun vector lies in the xz plane. Basically I need to find the rotation matrix that I can apply to the vector. I have been googling for over a day without any result. Can you point me to an article or book with a good explanation and derivation or explain how this is done? Thank you.
It is probably a composition of several rotation matrices.
You need to rephrase your question in terms of the various rotations involved.
Doing so you will probably see how to calculate your overall rotation matrix.
Eventually, this might help us too.
I will make an example. The Sun-Earth system - the Earth rotates about its own axis and at the same time it also orbits the Sun. I choose a coordinate system that corotates with the Earth (z axis is the spin axis) and I need to find how the direction vector to the Sun evolves with time. Unlike Earth - Sun system I presume circular orbit.
For example at t0 = 0, the non-normalized Sun direction vector is (1,0,1) and I want to know what is this vector at some time t (given the ω rotation angular speed and Ω orbiting angular speed).
(The same problem can be viewed from another coordinate system - Sun centric, where the z axis is perpendicular to the orbital plane and x-axis is the direction to the Earth at t0. In this case I need to know the time evolution of a normal to the Earth surface given at t0.)
The Earth - Sun system is just an illustration of the rotations involved. I need this for a general case of a body orbiting another body while rotating about its axis.
This cannot be done as composition of rotation matrices, they do not commute and the results depend on what rotation I do first. I believe the proper derivation must start with the equations of motion.
Composition of reference frames does not necessarily commute in three dimensions. Matrix multiplication is not commutative: A*B ≠ B*A in general.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
