What is the domain of f(f(x)) for f(x)= x/(1+x)?
The function f(x) = x/(1+x) leads to f(f(x)) = x/(1+2x). The initial domain found was incorrect; the correct domain is (-∞,-1)∪(-1,-1/2)∪(-1/2,∞). The mistake was in not accounting for the values that make f(f(x)) undefined, specifically when x = -1/2. The intersection of the domains must be carefully calculated to ensure all restrictions are considered. Understanding these domain restrictions is crucial for accurately determining the function's behavior.
Jpyhsics
f(x)= x/(1+x)
What is f(f(x)) and what is its domain.
2. The attempt at a solution
I found f(f(x))= x/(1+2x)
and the domain: (-∞,-1/2)∪(-1/2,∞) , but it is saying that I have the wrong domain. What mistake have I made?
My process for finding domain:
1. Find the domain of f : x≠-1
2. Use the definition D: {x∈(-∞,-1)∪(-1,∞) | (x/1+x) ≠ -1}
3. Find the ∩ (intersection) for the two domains.
Jpyhsics said:
f(x)= x/(1+x)
What is ##f(f(-1)##?
Likes SammyS
Oh I see! Its undefined!
So I guess my domain should be (-∞,-1)∪(-1,-1/2)∪(-1/2,∞)
Thank You!
Likes Delta2
Thank You!
Formally: if ##D_1 = A \cup B## and ##D_2 = C \cup D## then $$ D_1 \cap D_2 = (A\cap C) \cup (A \cap D) \cup (B \cap A) \cup (B \cap D)$$ Apply this to ##A = (-\infty,-1),## ##B = (-1,\infty)##, ##C = (-\infty, -1/2)## and ##D = (-1/2,\infty).##
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
