Composition of transformations
fk378
Suppose T is a rotation by 30 degrees about the point 2, and S is a rotation by 45 degrees about the point 4. What is T composed with S? Can you describe this transformation geometrically?
none
I know T composed with S means S is the first transformation we want to do, and T is second. But I'm not sure how we can rotate about the point 4, and then rotate about the point 2.
Hi fk378! :wink:
Hold your hand out, and put in on a table … that's point 2.
Now rotate your whole body (keeping your arm stiff) 30º about point 2.
Let your feet now be at point 4.
Rotate your whole body (keeping your arm stiff) 45º about point 4.
What's the result? :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
