Compton Scattering/Conservation Of Energy
  • Thread starter Thread starter ri0t
    Energy
In the discussion on Compton Scattering, a problem involving an x-ray photon colliding with an electron is analyzed. The initial energy of the photon is calculated using the formula E=hc/lambda, yielding a value of 7.96e-15 J. However, the focus is on determining the energy acquired by the electron and the change in the x-ray's wavelength post-collision. The key point is that the change in wavelength, which can be calculated using a specific formula related to Compton Scattering, is essential for finding the energy lost by the photon and gained by the electron. Understanding this relationship is crucial for solving the problem correctly.
ri0t
An x-ray photon of wavelength 0.025 nm collides elastically with an electron and scatters through an angle of 90 degrees. How much energy did the electron acquire in this collision and in what way did the x-ray change?
E=pc
E=hc/lambda
E=hc/lambda to get energy, which didn't work
(6.63e-34)(3.0e8)/(2.5e-11) = 7.96e-15 J
Then I read the whole chapter on it and could not find out how, exactly, to relate the two together, thus allowing me to figure out individual energy for the electron. The answer is 7.0e-16, which is pretty irrelevant because I want to know how to do it. Thanks for any input.
You are finding the initial energy of the photon, not the energy lost in the collision.
When the x-ray photon hits the electron it loses some energy to the electron and thus it's wavelength will change. Thus, you need to find this change in wavelength to find the energy gained by the electron.
HINT:
There is a special formula for change in wavelength due to Compton Scattering, and if you text has a section on the Compton Effect, I am sure its in there.
HINT:
I'm going to go ahead and assume the formula in which you speak is lambda = h/mc(1-Costheta), but it doesn't make any sense because you can't get energy from it.
That's where I'm lost.
Remember, the energy of a photon is related to its frequency (and therefore wavelength). So if you know the change in the wavelength of the photon, you can figure out what the wavelength is after the collision (since you know its initial wavelength) and what its new energy is.
