Computing operator in bra-ket within momentum space
Void123
[itex]<e^{ip'x}|x^{2}|e^{ipx}>[/itex]
Its pretty obvious that its difficult to integrate in position-space, so I rewrite x in momentum space (i.e. the second-order differential operator with respect to p).
If that is the case, is this correct (which is the part I'm not sure about):
[itex]C \int^{-\infty}_{-\infty} e^{ip'x}\frac{∂^{2}}{∂p^{2}}e^{ipx} dp[/itex]
(hbar is absorbed into the constant on the side)
Or do I have to Fourier transform [itex]e^{ip'x}[/itex] and [itex]e^{ipx}[/itex]?
Thanks.
[itex]e^{ipx}[/itex] is the wavefunction given in position space, so if you want to integrate in momentum space, you need to express the wavefunctions in momentum space as well, which should be [itex]\delta(p_1-p)[/itex]
