Comsol: Utilizing Symmetry Planes for Finer Grid
  • Thread starter Thread starter lucky_1809
    Planes
The discussion focuses on utilizing symmetry planes in COMSOL to create a finer grid for a structural model. The user has successfully reduced degrees of freedom by modeling only a quarter of the geometry, which includes both solid and shell subdomains. However, they are encountering issues with eigenfrequency calculations, finding significantly higher frequencies when using symmetry constraints compared to the global geometry model. The user suspects that COMSOL may be misinterpreting the symmetry constraints as external rather than true symmetry planes. Clarification on how to properly implement these symmetry conditions is sought to align the results with experimental findings.
lucky_1809
Hi
I realize a model that requires a very fine grid in comsol, so i have reduced the DoFs using symmetry planes. My structural model has 2 symmetry planes, so i have built a quarter of the total model, but now I don't know the way to tell to comsol that the realized model is only a quarter of the total...help me please!
what is the phisics of your subdomain? I use a symmetry boundary condition for a fluid and plane symmetry (corrisponding to the goemetry plane's symmetry) for a solid.
hello, forgive me for the delay in the answer but i was on holiday in cyprus, very beautiful place...My model is structural model with solid subdomain and shell subdomain, and I want to find eigenfrequencies... I tried to find eigenfrequencies in 2 ways...I realized the global geometry and after a slowly processing i found eigenfrequencies that are about the frequencies founded in experimental activity(the first f = 3.5Hz)..after i have built a quarter geometry and I put symmetry constraints like you told me, but I found very high frequencies (the first f = 1345 Hz). I supposed that comsol considers this constraints in a wrong way like an external constraint and not a symmetry plane.thank you
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
