Concentration and pressure problem. Need help
The discussion focuses on calculating the total pressure at equilibrium for the decomposition of ammonium carbamate (NH2COONH4) into ammonia (NH3) and carbon dioxide (CO2) in a specified volume. At 442 K, the equilibrium constant Kc is given as 0.043, with a concentration of NH2COONH4 calculated at 0.2613. The correct total pressure at equilibrium for 10.2 g of ammonium carbamate in a 0.500 L container is determined to be 2.40E1. Additionally, a similar problem is posed regarding the introduction of ammonium carbamate into a 0.400 L container at 37 ºC, where Kc is 4.1. The thread seeks assistance in deriving the equilibrium constant expression and solving for the total amount of ammonium carbamate at equilibrium.
ddluu
Ammonium carbamate (NH2COONH4) is found in the blood and urine of mammals. At a temperature of 442 K, Kc = 0.043 for the following equilibrium:
NH2COONH4(s) <=> 2 NH3(g) + CO2(g).
If 10.2 g of ammonium carbamate is introduced into a 0.500 L container, what is the total pressure inside the container at equilibrium?
Correct answer 2.40E1 (2.40 * 101)
Concentration of NH2COONH4: 0.2613
If someone would help me, I would very much appreciate it.
first write out the equilibrium constant expression
Concentration problem. Need help!
Ammonium carbamate (NH2COONH4) is introduced into a 0,4 L container, at a temperature of 37 ºC, Kc = 4,1 for the following equilibrium:
What is total of ammonium carbamate is introduced into a 0.400 L container at equilibrium?
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
