Concentration of ions in a reaction
To determine the concentration of ions in a reaction, it is essential to start with a balanced chemical equation and then derive the net ionic equation. The net ionic equation is crucial as it highlights the ions that participate directly in the reaction, allowing for a clearer understanding of the changes in ion concentration. It's important to note that the number of ions before and after a reaction may not be the same, as reactions can produce gases, precipitates, or other ions, which alters the total ion count. However, the conservation of mass principle holds; while the number of ions may change, the total number of atoms remains constant. This distinction is vital to avoid misconceptions about mass conservation in chemical reactions.
Trooper100
Alright guys, I am a little bit confused on how to find the concentration of ions in a reaction. In a solution, it is relatively easy.
Are the number of ions in the beginning the same they are in the end?
Please give me some general guidelines: i know to begin with a balanced equation , then a net ioc equation...but how does the net ionic equation help me??
Thank you so much, I will further update this question...so I can't specifically put my questions into words!
Any help appreciated, thank you so much.
Chemistry news on Phys.org
What do you mean by "the concentration of ions in a reaction"? Do you mean that you need to find the concentration of a solution after a reaction?
Not necessarily. Ions may be involved in many reactions where gases, precipitates, other ions etc. are formed, so the number of ions after a reaction will not generally be the same as before the reaction.
Could you provide a specific example of what you are trying to do?
I believe this is a dangerous wording (even if correct), as it may be read by someone that mass conservation is violated. And knowing students if something can be understood incorrectly, it will be.
Heck, even if something is worded in a way that can't be understood incorrectly, it will, against all odds.
Number of ions can change, but those that have "disappeared" are still there, just in different form. Number of atoms of an element (in all oxidation states) have not changed.
Ok...thanks for the help anyway. I think I got it, thank you everyone.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
