Conceptual Center of Mass acceleration problem
The discussion revolves around the acceleration of the center of mass (CoM) of three identical blocks on a frictionless surface, each subjected to equal forces applied at different points. It is clarified that the CoM motion is determined solely by the net external forces acting on the blocks, which are identical for all three, resulting in the same linear acceleration. The forces applied off-center create varying degrees of torque, affecting the blocks' rotational motion but not their linear acceleration. The consensus is that while the blocks may rotate differently, their CoM accelerations remain equal due to the identical forces. Understanding the distinction between linear and angular motion is emphasized as crucial for solving the problem.
bocobuff
3 identical rectangular blocks on frictionless surface have equal magnitudes of force and in the same direction are exerted on them. The CoM is the same for all the blocks and in the center of the rectangle. For block 1, the force is exerted to the left of the CoM, and halfway to the edge of the rectangle. Block 2, the force is exerted at the CoM and for block 3, the force is exerted on the far right edge of the rectangle. What is the direction of the acceleration of the block's CoM? Rank the magnitudes of CoM accelerations.
The attempt at a solution
I am thinking that block 1 will move cw, block 2 will go straight, and block 3 will go ccw. Also I think the magnitude of Block 3 is greater than blcok 1 because the distance between CoM and where the force is applied for block 1 is half that of block 3.
I can envision the whole movement but I can't think about the direction of the CoM. Anything would help.
please...
The distance from the C of M will determine which portion of the force will go into torque and which portion will go into translating linear motion won't it?
2 will go straight as you suggest with nothing to introduce torque..
The only problem you have is determining which of the other 2 will give more linear motion and to which direction the center of mass will fall off onto.
So less force is going to torque in block 1 because the point of force is closer to the CoM? Which would mean that it has a greater linear acceleration? So am I supposed to compare the magnitudes of the angular acceleration of CoM or linear?
I hope not. Only rank them looks like to me.
Cheers
I must be retarded then. Still don't get it. Wouldn't the force exerted be the tangential component that causes torque?
The CoM motion is determined only by the net force on the block, and so is equal for all 3 blocks.
There is no "portion of the force" that goes into translating linear motion.
Since it is frictionless and the blocks do have mass there will be varying degrees of linear momentum and angular momentum imparted. In 2) there is no net torque and so it is all linear. In 1) there will be a force couple between mass toward the outside edge, and the mass toward the center of mass. In 3) the force couple will be potentially minimal, hence the center of mass will will drift more quickly away than 1)as the edge is engaged.
I think you need to read the problem more carefully. Only one of the forces is acting directly through the center of mass of a block. That force will produce only a change in linear momentum. The other 2 are applied in an unbalanced way.
The accelerations are all three the same. The amounts of work done by the identical forces are different, and that's how some blocks will rotate in addition to their *identical* CoM motions.
Check your textbook, and see what causes the CoM motion.
You sum all external forces, independent of where they act.
Borgwal, my apologies. You are exactly right. It was my muddy thinking. Thank you for straightening out my faulty understanding.
So bocobuff, please disregard my earlier direction. That was incorrect on my part. The forces will act on the CoM as Borgwal has indicated.
Okay, no problem!
