How Do You Calculate Conditional Probabilities with Joint PDFs?
  • Thread starter Thread starter franz32
    Conditional
To calculate the conditional probability P(Y < 1 | X < 1) using the joint PDF f(x,y) = 2e^[-(x+y)], the definition of conditional probability is applied: P(A/B) = P(AB)/P(B). The joint probability P(Y < 1 and X < 1) is found by integrating the joint PDF over the appropriate region defined by 0 < x < y and y < 1, resulting in a triangular area. For P(X < 1), the integration is performed over the region where x < 1 and y > x, which creates a different geometric shape for integration. The calculations involve changing the limits of integration and applying transformations to simplify the integrals.
franz32
I just need a guide to this problem... found in one of the books in the library...
Given the joint pdf f(x,y) = 2e^[-(x+y)] where 0 < x < y, y > 0
find P(Y < 1 / x < 1). Note that "/" means given that.
I got the formula when P(a < Y < b / X = x) is given, i.e., in terms of the integral from a to b of f(y/x)dy. But how about this? Is there a formula to transform this? =) The answer is in the book... so I want to know how to begin with...
I think the probability density function was given as
and f(x,y)=0 if x>y.
Let be the event A: y<1 and the event B: x<1.
By the definition of conditional probability P(A/B) = P(AB)/P(B). (AB means A AND B). You have to integrate f(x,y) to get the probabilities. Find the integration domains in the picture: for P(AB), it is 0<x<y, 0<y<1. For P(B), it is x<y<infinity, 0<x<1.
ehild
To solve this problem, we can use the definition of conditional probability, which states that P(A/B) = P(A and B)/P(B). In this case, we are trying to find P(Y < 1 / X < 1), so we can rewrite this as P(Y < 1 and X < 1) / P(X < 1).
To find the joint probability P(Y < 1 and X < 1), we can integrate the joint pdf f(x,y) over the region where both x and y are less than 1. This region can be represented as a triangle with vertices at (0,0), (1,0), and (1,1). So the integral becomes:
∫∫ f(x,y) dx dy = ∫∫ 2e^[-(x+y)] dx dy = 2∫∫ e^[-(x+y)] dx dy
Since the integral is over a triangle, we can change the limits of integration to make the calculations easier. Let u = x+y and v = y, then the triangle becomes a rectangle with vertices at (0,0), (1,0), (1,1). The limits of integration become 0 to 1 for both u and v. The Jacobian of this transformation is 1, so the integral becomes:
2∫∫ e^[-u] du dv = 2∫ e^[-u] dv = 2e^-u ∫ dv = 2e^-u (v) = 2e^-u (1-0) = 2e^-u
Now, to find P(X < 1), we can integrate the joint pdf f(x,y) over the region where x is less than 1. This region can be represented as a triangle with vertices at (0,0), (1,0), and (1,∞). So the integral becomes:
Again, we can change the limits of integration to make the calculations easier. Let u = x+y and v = y, then the triangle becomes a trapezoid with vertices at (0,0), (1,0), (1,∞), and (0,
