Conditional probability problem
The discussion revolves around a conditional probability problem involving randomly formed couples in a city with equal numbers of good-looking gentlemen and ladies, each constituting 10% of their respective groups. The main question is to determine the probability that if one member of a couple is good-looking, the other member is also good-looking. Participants express confusion about the nature of randomness in coupling and how it affects the probability calculations. A key point made is the distinction between the phrasing of the problem, emphasizing that it refers to "a member of a couple" rather than a specific member, which significantly impacts the probability outcome. The conversation suggests using visual aids like tree diagrams to better understand the relationships and probabilities involved.
kenny1999
This is in fact an example with solutions. but I don't understand the solutions. So I am here to ask for explanation.
Details are;
In a city there are equal number of gentleman and ladies. 10% of gentleman are regarded as "good-looking" while 10% of ladies regarded as "good-looking". People form couples randomly.
Given that a member of a couple is good-looking, find the probability that the other member is also good-looking
They first define
G: set of good looking gentleman
L: set of good looking ladiesthen i start to confuse here...
P(the other is good-looking AND a member is good-looking)
= P((L and G)and(L Union G))
= P(L and G)
P(a member is good looking)
=P(L Union G)
the solution and the problem is an example of conditional probability stated in the materials
but... i just don't understandIn my opinion, since the first member of a couple is GIVEN to be good-looking while people form couple randomly, then it should mean that a good looking member will not have a higher or less chance of finding a good-looking member to form couple. Then why it is a conditional probability?
Details are;
They first define
= P(L and G)
=P(L Union G)
Be very, very careful about wording: the question did not say "first member of a couple..." (those were *your* words), it just said "a member of a couple...". Believe it or not, that makes all the difference in the world!
Consider a related case that might be easier to work with: say we toss two fair coins once. Outcomes are of the form HH,HT,TH,TT, where these are for coin1, coin2 in that order. If I ask: "given that the first coin shows heads, what is the probability the second coin show heads", the answer would be 1/2. If I ask "given that one coin shows heads, what is the probability that the other coin shows heads" the answer would be 1/3. A similar type of thing is occurring in this problem.
RGV
RGV
yes, but the problem is, they choose another to couple RANDOMLY. A given good looking member will not have higher or less chance coupling with another one who is either good-looking or not. Imagine a good looking member, he/she has 10% chance of coupling a good looking member too. Isn't it? if not, I really don't undesrtad what is meant by "random"
I would suggest you draw a tree diagram. It is often much easier to figure these types of problems out if you have something to help you visualize.
Go back to my two-coins example, as it is a bit easier to work with. Again, the list of possible outcomes is HH, HT, TH, TT, all equally likely. You pick one of these 4 outcomes at random, and it happens to have a H in it (that is, it is not the outcome TT). So, you must have picked either HH, HT or TH, and they are still equally likely. So, having observed an 'H' as a result of a random choice, there is now a 1/3 chance you chose HH---after all, it is the one out of three equally likely options.
RGV
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
