MHB What Is the Probability Distribution for Drawing Spades Without Replacement?
The discussion focuses on calculating the probability distribution for drawing spades from a deck of cards without replacement. The initial poster presents their calculations for the probabilities of drawing spades on successive draws, using conditional probabilities. Other participants clarify that the question likely seeks the probabilities of drawing 0, 1, 2, or 3 spades, suggesting the use of the hyper-geometric distribution. They provide specific calculations for these probabilities and emphasize the importance of ensuring that the total probabilities sum to one. The conversation highlights the need for clear interpretation and accurate calculations in probability problems.
Roohul Amin
Dear All sorry for repeated post;
There is a problem
Problem: Three cards are drawn in succession from a deck without replacement. find the probability distribution for the number of spades.
I have come with this solution.
Let S1: appearance of spade on first draw S2: appearance of spade on 2nd draw S3: appearance of spade on 3rd draw
S01: No spade on 1st draw S02: No spade on 2nd draw
P(S1)=13/52
P(S2)=P(S2/S1)+P(S2/S0)=12/51+13/51
P(S3)=P(S3/S01*S02)+P(S3/S1*S02)+P(S3/S1*S2)=13/50+12/50+11/50
Need your opinion Please!
Mathematics news on Phys.org
Hi there,
So a probability distribution is a function of some kind of input parameter(s). Are you asking what is the probability of drawing three spades or trying to generalize the distribution in terms of the three draws?
In either case the final result would be a multiplication, not a sum. I think you are in the right direction but some clarification on the question would be helpful.
If you want an exhaustive list of possible outcomes, the event is spade/no spade, so the total number of outcomes is $2^3=8$.
Thanks for your reply Jamson: it seems the hyper-geometric distribution fit well this situation, what do you think?
There is a problem
P(S1)=13/52
I am not entirely sure that I understand the question. But I think that it is asking for the probabilities for drawing 0, 1, 2 or 3 spades.
Let $P(n)$ denote the probability of drawing $n$ spades. Then $P(0) = \dfrac{39 \cdot 38 \cdot 37}{52 \cdot 51 \cdot 50} \approx 0.4135$.
For $P(1)$ we have to draw one spade and two non-spades. There are three possibilities, since the one spade could be either the first, the second or the third card drawn. So $P(1) = \dfrac{3 \cdot 39 \cdot 38 \cdot 13}{52 \cdot 51 \cdot 50} \approx 0.4359.$
In a similar way, you can calculate $P(2)$ and $P(3)$.
If I am interpreting the question correctly, you answer should be the set of four probabilities $P(0),\ldots,P(3)$. As a check, you should verify that your four probabilities add up to $1$.
in the denominator the values are clearly 52C3. But the values in numerator i.e 3.52.52.39 are making some confusion to me, would you pleas give details. Thanks
Sorry, my mistake. I should have written 3.39.38.13 there (I have now corrected it). The idea is that if you want just one of the three cards to be a spade, then you have 39 choices for the first non-spade, 38 for the second non-spade, and 13 for the spade. The 3 (as I mentioned in my previous comment) comes from the fact that the spade could be either the first, the second, or the third card to be chosen.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
