- 1,494
- 2
Obtain the temperature distribution T(x,y) of the triangular cross section, assuming constant thermal conductivity, k.
The triangle is a right-isosceles triangle with the right angle at (0,0). The triangle goes "up" to a, and to the right to a, then diagonally across. Imagine a square split from top left to bottom right.
Most importantly the bottom is held at T2, and the left and diagonal sides are held at T1.
The relevant equation would be the general heat conduction equation.
We had a similar problem where the diagonal was insulated. This let you actually pretend you had a square where the top was at T1 also, and the right at T2. Then you used a symmetry line and used the principle of super-position to solve the problem. You would first define a variable theta = T - T2. Then you have homogenous boundary conditions on the bottom and right. Then superimposed solutions for the top theta = T1 - T2 and the left theta = T1 - T2.
The problem with this one is that you cannot do this, since the diagonal is not insulated, so it's not a symmetry line, and I have no idea how to start.
