Conductor Bundles: Reduce Impedance Per Meter
In summary, the electrostatic radius is greater for a cage than for a single wire, which reduces corona discharge but also increases capacitance per unit length to other bundles and to ground. Because the currents are shared by the conductors of the cage, those currents are further apart than they would be on a single conductor, so there is less magnetic coupling of the currents. That reduces the self inductance per unit length of the cage. The characteristic impedance of a transmission line, Zo = √ ( L / C ). When using a cage, L is reduced, and C is increased, so the impedance of a line, or a dipole over ground, will be lower than that of a single wire. Another advantage of a cage
chopficaro
46
http://www.kabculus.com/capacitance-and-inductance-matrices/node7.html
this short page describes conductor bundles, which are power transmission lines hung parallel to each other. i think the page is trying to explain why, when they are hung that way that they reduce impedance per meter, but i don't get it. i understand all the variables they are using except what it is they are calculating.
r is an approximation for the radius of the conductors' cross section (i think)
R is how far away the cables are hung from the center of the bundle (i think)
e0 is the permeability of free space
potential? that means voltage right? why are they using the greek letter for angle? why isn't it 120v rms?
and what is a2 and a4? equivalent radius?
You mention 120V AC, but bundled conductor power lines are used at 345 KV or higher. Shift your horizon a whole lot.
If we used a single but thicker conductor, the volts/meter gradient would be higher. That increases corona losses.
You also should think of the skin effect. AC current tends to run on the outside of the conductor. i.e. the skin. So the ideal profile would be a hollow cylinder, not a solid wire. But 3 conductors in a triangle shape, approximate a hollow cylinder. Even more conductors, the better the approximation.
Likes DaveE and Baluncore
The same technique is used for radio antennas where they are called cage lines, or cage dipoles.
The electrostatic radius is greater for a cage than for a single wire. That reduces corona discharge, but it also increases the capacitance per unit length to other bundles and to ground.
Another advantage of a cage for dipole elements is that the radius can be reduced in the element as it approaches a conductive tower or supporting structure. That reduces impedance changes along the element, so it reduces losses and raises the Q of the dipole.
According to Electrostatics Theory the surface integral around an electric charge Q of the electric field flux density D it is equal to this charge [Gauss' law].D=ε.E where E it is the electric field [intensity].
So ε.E*2.п.r.length=Q or E(r)=Q/(2.п.ε)/r/length
The electric potential[aka voltage] V=ʃE.dr=Q/(2.п.ε).ln(r2/r1) per unit length.
The Green function it seems to be the potential per unit length and unit charge.
For bundled parallel wires see the link-for instance:
http://users.ece.utexas.edu/~baldick/classes/369/Lecture_6.ppt
FAQ: Conductor Bundles: Reduce Impedance Per Meter
What is a conductor bundle?
A conductor bundle is a group of conductors that are twisted or braided together to form a single unit. It is used to carry electric current and is commonly found in power lines and cables.
How does a conductor bundle reduce impedance per meter?
When conductors are bundled together, the electromagnetic fields surrounding each conductor cancel each other out, resulting in a lower overall impedance. This is because the current flowing through the conductors creates opposing magnetic fields, which can interfere with each other and increase the overall impedance. Bundling the conductors reduces this interference and thus reduces impedance per meter.
What are the benefits of reducing impedance per meter?
Reducing impedance per meter can improve the efficiency of the electrical system. This means that less energy is lost during transmission, resulting in lower costs and a more reliable power supply. It also allows for longer distances of transmission without significant voltage drops.
Are there any drawbacks to using conductor bundles?
The main drawback of using conductor bundles is that they can be more expensive to manufacture and install compared to single conductors. Additionally, if one of the conductors in a bundle fails, it can be more difficult to identify and replace compared to a single conductor.
Are there any safety concerns with conductor bundles?
As with any electrical system, there are potential safety concerns with conductor bundles. If they are not installed or maintained properly, there is a risk of electrical fires or other hazards. It is important to follow safety guidelines and regulations when working with conductor bundles.
